Go to Post I always wondered what would happen if two robots mated. - Greg Needel [more]
Unread 21-03-2011, 10:59
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: Window Motor locking up
Guys,
There are several threads related to this issue. Window motors have a set of locking pins that seem to interact with the higher switching frequency in the Jags. Once locked, the motor has to be reversed to release the pins and allow forward motion. The rules this year allow you to remove the pins if your design does not need them. If the pins are locked and you continue to push the motor, it will over heat and the PTC will limit the current through the motor. For info on removing the pins, search window motors and John Novak. You will find a procedure for removing the pins.
We had issues with our window motors used for our arm locking up as well.
We found John Novak's post, which pointed to the previous post in the same thread by Gdeaver (Team 1640). Gdeaver provided a link to Team 1640's wiki describing the step-by-step procedure (with photos!) for removing the locking pins from the window motors. Work carefully when removing the retainer clip, as to not destroy it. That clip need to be re-installed after the pins are removed.
Our arm has worked well since removing those pins. Now the window motors are "back-drivable" and the arm "sags" when the motors are de-energized. Still, this is far better than the arm locking-up when you need to move it.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 21-03-2011, 22:59
Vermeulen's Avatar
Vermeulen Vermeulen is offline
I have too much free time now
AKA: Tom Vermeulen
FRC #1306 (BadgerB.O.T.S.)
Vermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to all
We had the same problem on our forklift, which sounds almost the same as yours. We chose not to remove the locking pins on our window motors, as we wanted to have the forklift stay in position without moving the motors. We replaced the jaguar with a spike, and the problems stopped. As it turns out, we didn't necessarily need to have variable speed, anyway.
Congratulations Ben Senson on winning the 2012 Wisconsin Regional Woodie Flowers Finalist Award!
2012 Wisconsin Regional Semifinalist
2012 Wisconsin Regional Engineering Inspiration Award
2011 Wisconsin Regional Innovation in Control Award
2010 Wisconsin Regional Chairman's Award
2010 Wisconsin Regional Quarterfinalist
2010 Curie Division Quarterfinalist
Unread 22-03-2011, 02:42
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
our solution to the problem was to hook the jaguars we were using to 20 amp fuses on the pdb as a team suggested to us.
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 22-03-2011, 07:38
Explain please?!?!?
