Go to Post And the rest of the team helped them, encouraged them, and made a big deal about how awesome it was that we were competing for the Chairman's Award. - Carolyn_Grace [more]
Unread 22-03-2011, 01:23
WarehouseCrew WarehouseCrew is offline
FRC #3299 (Warehouse Crew)
Team Role: Parent
WarehouseCrew is an unknown quantity at this point
Minibot switches and soft landings
I have two questions that I would appreciate help with. What specific electrical switch is working to turn the minibot off after the top pole sensor is successfully tripped (but not turning off without triggering sensor)? We have one push button switch from Home Depot that takes about 7 pounds of pressure to turn it off. The fuse may trip before this works.
Secondly, how do you make the minibot come down the pole to a "soft landing"? I've read that some teams are using reduced power on the motors to provide a braking action after the top sensors is reached. How is that done (eg. my switches are only on and off, no 1/2 power option) and is there a risk of burning up the motors?
Thanks.
Unread 22-03-2011, 03:06
wevets wevets is offline
FRC #1510 (Wildcats)
wevets will become famous soon enough
Re: Minibot switches and soft landings
This circuit (click on image to see it enlarged):
(sorry for the bluriness) will make the robot come down the pole slowly. The robot takes off up the pole when S1 is closed. When S2, a SPDT switch, is thrown by contact with the top of the pole, it takes the battery out of the circut and connects the motors so that they act as generators into a short circuit load. (Note that the motors are not internally shorted, a bad thing.) This provides "dynamic braking" as the robot comes down the pole gently by gravity. It works quite nicely.
When taking the robot off the pole, open S1 then reset S2 to arm the minibot for the next run.
Unread 22-03-2011, 03:38
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
I can't help you if your switch will or will not trigger the sensor before turning the machine off w/o seeing your design. Much of the problems reported with minibots not triggering are with extremely fast and light minibots that do not keep the trigger held long enough for the system to register it.
I can tell you how to make it fall back down the pole slowly. Use a "3-way" "common household sw" or a 3 terminal "limit sw" to short the motor terminals together making the motor into a electric brake.
To wire either you connect the COM, common, or odd colored terminal to the terminal on the motor you want to be (+). One of the other terminals goes to B(+) and the remaining other terminal goes to B(-) and the motor terminals you want to be (-) when in the "on" position.
In one position the sw will connect B(+) to motor (+) and in the other it will connect motor (+) to motor (-) making it act as an electric brake.
If you are using 2 switches then place the "on" sw between B(+) and the off/brake sw.
Unread 22-03-2011, 16:20
Team Role: Parent
Thanks for the help. We will try this.
Unread 22-03-2011, 16:38
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
You don't necessarily need to make your minibot come down slowly. Our minibot hit the top, turned off, and then free falled down to hit either our deployer or the platform. Our minbot hasn't had any issues with this.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 22-03-2011, 18:18
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
Team 241 uses a high friction hinged flap over the top of the kit-of-parts limit switch. When the hinged flap hits the plate, it absorbs the energy in the friction on the hinge. The bottom of the flap then strikes the limit switch and the minibot starts down the pole in brake mode. The small spring in the limit switch is not strong enough to push the high friction hinged flap up. After the minibot comes down you manually have to put the flap back up and off the limit switch to be ready for the next race.
Our hinged flap is just a piece of angled aluminum connected to the minibot with a screw and TWO nuts as the hinge. The first nut is tightened until the hinge gives the right amount of friction, the second nut is tightened while securely holding the first nut in place. This will keep it from loosening.
The flap can also have a stop under it to assure the limit switch does not absorb the full blow of the tower plate. The stop can just be a well placed screw and nut.
Unread 22-03-2011, 21:22
DonRotolo's Avatar
Back to humble
FRC #0832
I saw team 75's minobot with a KoP microswitch limit switch, where they bent the lever into a "C" or 'hook' shape so when it is pressed down, it 'latches' under the body of the switch and keeps the switch "off". Since it's a SPDT switch, they use the NO contact to short out the motors as described above.
Unread 22-03-2011, 21:25
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
How did you turn 1 limit switch basically into a 3 way usually used to produce the break mode?
Unread 22-03-2011, 21:59
I know it is hard to read this in the rules for the minibot, but you can modify the light switch so that a plunger mechanism turns the switch off when it reaches the top. You can also use a lever to increase the pressure placed on the switch.
Unread 23-03-2011, 02:56
Mr V's Avatar
FRC #5588 (Reign)
The KoP limit switches are in essence identical to a "3 way" sw. How to make it so the off position if brake is detailed in post 2 and 3 of this thread.
Unread 23-03-2011, 07:42
boomergeek's Avatar
Here's a marked up diagram...
(I always tell students to use a continuity meter (ohm meter with a beep mode) and flip the switch on and off to make sure they know which terminal is the common before wiring anything- sometimes its easy to get confused by the markings).
Unread 23-03-2011, 20:06
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
UNTESTED: We have applyed a 'brain bucket' to our minibot...lime green...got us the imagery award at GVSU/West Michigan comp last week...Amen. Thats all I can say.
Unread 24-03-2011, 08:22
Vermeulen's Avatar
Vermeulen Vermeulen is offline
I have too much free time now
AKA: Tom Vermeulen
FRC #1306 (BadgerB.O.T.S.)
Vermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to all
We also did this. We had a small latex tubing cushion on the bottom, but removed it due to deployer issues. Our minibot never had any problems with this. On a semi-related note, you don't want to have the minibot contact the deployer if at all possible. I've seen red cards being given because of this.
Congratulations Ben Senson on winning the 2012 Wisconsin Regional Woodie Flowers Finalist Award!
2012 Wisconsin Regional Semifinalist
2012 Wisconsin Regional Engineering Inspiration Award
2011 Wisconsin Regional Innovation in Control Award
2010 Wisconsin Regional Chairman's Award
2010 Wisconsin Regional Quarterfinalist
2010 Curie Division Quarterfinalist
Unread 24-03-2011, 08:36
Brandon Holley's Avatar
Can you provide a rule that would indicate this is a red card/yellow card/penalty?
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 24-03-2011, 17:28
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
<G22> HOSTBOTS may not contact their ALLIANCE‟S MINIBOT while any part of it is above the DEPLOYMENT LINE.
