Go to Post I swear, sometimes it seems like FIRST has got a room full of monkeys writing code. Maybe the monkeys should spend less time flinging fecal matter at each other and more time testing the code before posting it :-). - Kevin Watson [more]
Unread 22-03-2011, 22:50
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Minibot & Tetrix Modifications
Can the aluminum Tetrix channels be modified by cutting slots or enlarging holes? I would assume yes, but, since the rules seem to be geared towards what is permitted, I can't find anything specifically permitting or prohibiting it.
Unread 22-03-2011, 22:52
Re: Minibot & Tetrix Modifications
You're correct; Q&A did clarify that a while back. Modify as needed.
Unread 22-03-2011, 22:55
William,
R92 relates to materials that are allowed, it does not speak to which form they are used in your design. We do need to identify what the part started out as if it fits one of the sub paragraphs. PVC pipe or fittings for example.
Unread 23-03-2011, 08:33
AKA: William Lydick
no team (n/a)
Thank you, EricH & Al. I had hoped that it was just that easy.
Good luck with the rest of your season.
