Go to Post Getting a swerve to drive predictably and effectively is arguably harder than designing and building it. - Holtzman [more]
Unread 22-03-2011, 22:52
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Team 3309 SuperRouter (TM)
Is Joke.
Must Be.
"Overclocking" will mess up data timing (based on the system clock, right?) causing instant and complete loss of any communication.
If they modified the router for more power, I wouldn't want to be the one to give the FCC the evidence on a public forum. Might want to check the dollar amounts on the NAL (fine) for doing such things. Lots of zeros in that number.
Conclusion: Must be joke.
Unread 23-03-2011, 21:59
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
This intriques me as I attached a photo of the Overclocking frequencies for my router. I have toyed with it in the past and I never noticed any communication issues.
Going to bump it up from 228 to 252 mhz for a few minutes and see if I notice a lot of dropped packets.
Edit: Didn't seem to notice any performance difference.
Name:	Screen shot 2011-03-23 at 8.56.54 PM.png
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 23-03-2011, 22:25
David Dawson's Avatar
David Dawson David Dawson is offline
Capt'n turned Mentor
FRC #3771 (Yooper Troopers)
David Dawson will become famous soon enoughDavid Dawson will become famous soon enough
I'm pretty sure the FCC wouldn't bother anybody that is abusing the 2.4 ghz band. They only go after people interfering with private licensed bands.
Unread 23-03-2011, 22:33
DonRotolo's Avatar
Back to humble
FRC #0832
Thinking about it, I can't imagine they'd base the data on the clock without compensating for a frequency change that's done in software.
For the most part. This has more to do with voiding type acceptance than with interference. Also enforcement actions are usually based on complaints they receive.
The NJ State Police also don't stop you for doing 67 in a 65, but that doesn't mean they can't or won't.
Unread 23-03-2011, 12:27
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Originally Posted by Friarbots View Post
This particular router doesn't support the "overclocking" feature of the DD-WRT firmware, we should have been more clear in that we set the TXPower to a higher setting and modified the afterburner preferences.
This is not a joke.
You are likely violating FCC laws by doing so, FYI. The router is tested & certified at the settings as shipped; modifying it invalidates that certification.
{edit} It's also quite common to burn things out after a while on these routers by maxing the TX power. Just because the setting is there buried in firmware doesn't mean the hardware can actually handle it.
{edit again} I see Don already pointed out the FCC angle but it doesn't hurt to repeat it. He's not kidding about lots of digits in the dollar amount if you're caught & fined.
Unread 23-03-2011, 18:24
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Post #5 on this thread was not accurate information and was posted by another team member who didn't understand the gist of this thread. This is all done in jest so should be considered a "joke"
Just to clarify-this was a project embarked on for fun, not for actual use in the competition or in any real-world applications.
This router has provided poor performance overall in our testing (which happens primarily outdoors) and as it's worth only $29.99 we decided to embark on some experimenting with DD-WRT
We increased the Tx Power which did improve ping times but reliability is not perfect. As we are not using this router for any actual applications (replaced with a couple of WRT54G's, completely stock, which work very well) FCC violations shouldn't be relevant and we'll make sure to keep this thing out of production environments.
I hope somebody got a few chuckles out of this Perhaps we should have waited until April Fools!
Good luck at your competitions everyone!
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 23-03-2011, 21:42
DonRotolo's Avatar
Back to humble
FRC #0832
sigh.
If you modify a type-accepted device you have voided (as in nullified, removed) its type acceptance.
Allowing a non-type accepted device to emit Radio Energy* outside a screen room is cause for FCC action (in the USA). It does not matter if you use the equipment or not.
Will they catch you? Unlikely.
Will they fine you if they do catch you? Probably not
Is the potential fine above $100,000? Yes.
Your call.
* (Specifically, energy above a certain level, which is measured as a field strength at a certain distance. A microwatt from an 802.11 device exceeds this threshold, that's well over 1/1000 of normal power)
I'm just trying to tell you that you're breaking the law, and you should stop.
