Go to Post oooo can i get bear hugged at monty madness...please big mike, please - Rohith Surampudi [more]
Unread 22-03-2011, 22:11
Bharat Nain's Avatar
Team update 19
Team update 19 has been posted:
http://usfirst.org/uploadedFiles/Rob..._Update_19.pdf
It contains a new cRio update for teams using CAN.
Also, an explanation of how the tower triggering mechanism works.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 22-03-2011, 22:29
Andrew Lawrence
Posts: n/a
Re: Team update 19
No major game-changing rules. I'm fine with that. MESSAGE TO ALL TEAMS: GET THE NEW C-RIO UPDATE. WE'VE HAD TIMES IN THE PAST WHERE ONLY THE NEWEST VERSIONS WOULD WORK
Unread 22-03-2011, 22:35
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Team update 19
The tower triggering explanation should end speculation on how it works. I'd opine that a 1 mSec debounce buffer is not an issue: If your minibot hits the target (and not the bolts) the tower will trigger.
Week 3 starts soon, I'm still hoping to hear any reports of towers not reasonably triggering.
Unread 22-03-2011, 23:47
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Re: Team update 19
Week 3 has been and gone. I hope you didn't forget to attend a Regional Don!
I'm a little envious from the Team Update #19 quote
"this update has been tested with a number of FRC robots in competition"
We remained stationary in a semi-final match due to the exact conditions which this bug fixes (and a lack of defensive code on our part) and I'd have been prepared to take the risk of beta testing the fix had it been available to us.
Unread 23-03-2011, 10:15
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Team update 19
For those of you that aren't able to click the link, here is the portion about tower triggering:
Interest has been expressed by many teams on how the TRIGGERING of the TOWERS is
monitored. The following is a more technical explanation.
Each TOWER in LOGOMOTION has a dedicated module that monitors the trigger mechanism for
that TOWER and controls the lights at the top. The trigger mechanism activates at ~0.25 inches of
plate movement. The control module has a built-in noise buffer of 1ms. Any input signal longer than
the noise buffer is immediately time-stamped and reported back to the central field controller. This
central field controller then processes the received data every 5ms or less. Once the field controller
sees a TOWER as TRIGGERED, it assigns a finish place to that TOWER (1st, 2nd, 3rd, or 4th)
depending on the state of the remaining three TOWERS
So, can someone explain what all of this means? From what I understand, your minibot must move the top plate approximately 1/4" and hold the plate in the triggered position for longer than 1ms?
-Dustin Benedict
Unread 23-03-2011, 10:42
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Team update 19
From helping with the Towers at the Tel Aviv Regional, I learned that the triggering mechanism is simply 2 pieces of aluminum angle approx. 1/4 inch apart attached to the upper and lower tower plates that make contact when the lower tower plate is engaged by the minibot and pushed upward. Triggering is accomplished by completion of the circuit upon contact.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 23-03-2011, 22:08
nitneylion452's Avatar
AKA: Joe Lee
Re: Team update 19
That's also how I am understanding it, too.
EDIT:
I am a member of the Department of Redundancy Department
Unread 23-03-2011, 22:19
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Re: Team update 19
What it means is there is a little module in the tower that registers when the tower is held down for 1ms or longer, and the module tells the field management system every 5ms or less whether it has been activated and when. We still don't know what the field management system does with that trigger though. It's entirely possible that it requires a certain number of consecutive high signals from the module before counting the tower TRIGGERED.
Unread 24-03-2011, 01:55
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Team update 19
5ms is a significant amount of time; does anyone know what happens to ties? Let's hear it for a 60 point minibot race for one alliance!
Unread 24-03-2011, 02:52
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Re: Team update 19
I would guess that there is some kind of lockout system employed before the signal is sent to the FMS. Certainly if any trigger within 5ms caused a tie, I think we would have seen one by now.
Does anyone else remember when TBA signatures actually worked?
