Go to Post There are zillions more volunteers than paid staff. We are FIRST. - Rick TYler [more]
Unread 22-03-2011, 13:53
ProgramLuke's Avatar
ProgramLuke ProgramLuke is offline
Captain
AKA: Luke
FRC #2169 (KING TeC)
ProgramLuke is an unknown quantity at this point
CIM Motor Capacitors
Where is a good place to buy capacitors for the DC CIM Motors allowed under:
A one microfarad (1 μF) or less non-polarized capacitor may be applied across the power
leads of any motor on your ROBOT (as close to the actual motor leads as reasonably
possible)
2012 Inaugural Minnesota State High School League State Champions
2012 Galileo Division Semifinalists
2012 Wisconsin Regional Finalists
2012 Wisconsin Regional Entrepreneurship Award
2012 Lake Superior Regional Chairman's Award
2012 Lake Superior Regional Champion
2012 Lake Superior Innovation in Control
2011 Championship Imagery Award
2011 Championship Archimedes Quarterfinalist
2011 Minnesota 10000 Lakes Finalists
2011 Lake Superior Regional Chairman's Award
2011 Lake Superior Finalists
2010 FTC World Championship Finalist
2010 FTC World Championship Edison Division Champion
2010 Minnesota 10000 Lakes Regional Chairman's Award
2009 Minnesota North Star Regional Chairman's Award
2008 Wisconsin Regional Finalist
2007 Wisconsin Regional Champion
Unread 22-03-2011, 14:03
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Re: CIM Motor Capacitors
Locally? A Radio Shack. You may be able to find another electronic component store near you as well.
Online? Mouser, Digikey.
May I ask why you're doing this. Nothing wrong with it, but I'm just curious if you're having problems with the cRIO or the Dlink bridge cutting out.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 22-03-2011, 14:45
Luke,
I know that many teams do not think of moving the motor controller closer to the motor it controls but this is a good way to reduce motor noise and allow the motor to be connected directly to the controller without having to add wire to the motor. The CIM motor has not been known as a noise producer as compared to the FP for instance.
Unread 23-03-2011, 12:38
Captain
AKA: Luke
We are indeed having issues with communications. We are using all 4 CIMS on our drivetrain but if we don't have a battery that idles around 13V We lose comms if we try to accelerate quickly. What happens is that the Dlink drops out and we have to wait for it to restart to get communications. Are other teams having issues like this and do you have any solutions?
Unread 23-03-2011, 12:44
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
Do you have the power converter (12v in, 5v out) connected to the 12v output at the bottom of the PD board? And then the 5v from the converter feeds the radio.
2014 Wisconsin Engineering Inspiration Award, CIR Engineering Excellence Award
2013 Croosroads Engineering Inspiration Award
2012 BMR Judge's Award, 2011 BMR Regional Champions, BMR Motorola Quality Award, BMR Autodesk Excellence in Design Award, 2010 BMR Regional finalists; 2009 BMR General Motors Industrial Design Award; 2008 BMR Engineering Inspiration Award; 2007 BMR Rookie All-Star Award
Darrin Munter - N9SDD
Advanced Technology Services
Unread 23-03-2011, 12:54
Captain
AKA: Luke
Yes the Dlink is powered by the converter.
Unread 23-03-2011, 12:55
AKA: Darrin Munter
I found a PDF that shows how and where the converter gets connected.
File Type: pdf 2011 Robot_data_power_ Power Dist 2011 (12V) (1).pdf (264.0 KB, 46 views)
Unread 23-03-2011, 12:59
AKA: Darrin Munter
Can you block up your robot so you can run the motor and keep the robot in place?
You might want to take a voltage measument from the 12v coming from the PD board. If its going below 12V you have a problem with the PD.
That output has a special built in power supply that keeps the voltage steady at 12v - no matter what the battery is running at. ~ unless the battery drops way low, 7-8 volts.
Unread 23-03-2011, 13:01
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Luke,
Darrin's specific question included "Do you have the power converter (12v in, 5v out) connected to the 12v output at the bottom of the PD board?" for a very good reason.
If it is connected there, the regulator in the PDB will provide +12vdc even when the battery voltage dips below +12vdc. If the converter is not connected there, but is connected to the standard Wago connections, you will loose the +5vdc out of the converter when the voltage dips.
So, do you have the power converter (12v in, 5v out) connected to the 12v output at the bottom of the PD board?
Unread 23-03-2011, 13:15
Captain
AKA: Luke
That's one of the issues. Unless the battery is absolutely fully charged and reading 13v+ we will get a drop to 8v or less. At that point we get loss of communication. We just did a run reading 12.8 volts and it immediately dropped to 8v- and lost communication.
Unread 23-03-2011, 13:19
Captain
AKA: Luke
Thanks for the guidance. We had it coming out of the PD through a regular circuit. We will get that changed right away and see if it makes a difference. Really hoping this is the issue.
Thanks again!
Unread 23-03-2011, 13:20
RyanN's Avatar
RyanN
You're dropping too much. I'd look at the main power path from the battery all the way to the Power Distribution board. Bad crimps, looks nuts, nicked wire, undersized wire. You have too much resistance somewhere, or else some bad batteries.
A clue would be to feel all the wires from the battery terminals to the PD board. If any are warm, then there's your issue.
Also, 6AWG wire is a tiny bit small for the loads you might be putting on it. If you're running more than 2 feet of battery cable, I'd recommend bumping it up to 4AWG.
Also check for mechanical issues. Can you rotate your wheels pretty easily? Are they tough to spin? If they're tough, you might be binding too much and pulling too much current.
Controls Mentor
@rnazaretian
Previous teams:
Unread 23-03-2011, 13:21
AKA: Darrin Munter
Bad battery? We've had to get rid of about 2 of ours this year, because of that.
If your using a good battery, then you have excess load somewhere.
Run your motors one at a time and measure the battery voltage, the motor with the largest battery voltage drop is your problem. It could be the motor itself, or a speed controller going bad.
Unread 23-03-2011, 13:23
AKA: Darrin Munter
Thanks again!
We did the same thing two years ago! We were at the BMR, when a mentor from WildStang help us out.
Unread 23-03-2011, 13:32
RyanN's Avatar
RyanN
Thanks again!
Yep, that's the main issue. The 12V coming out of the bottom of the PD board is a boost circuit. It is supposed to operate down to a battery voltage of 4.5V.
http://usfirst.org/uploadedFiles/Rob...tion_Board.pdf
Page 6 of 10.
Controls Mentor
@rnazaretian
Previous teams:
