Go to Post That settles it, no questions left. Water game. - Lil' Lavery [more]
Unread 23-03-2011, 16:12
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: Help the field crew, reset your gyro in autonomous
Is there a way for us to know in the software if the FPGA is finished determining the gyro bias?
Unread 23-03-2011, 16:27
In LabVIEW, the gyro bias is done in the open, and is blocking. When the open returns, the bias calculation is done. In Java, the gyro bias is done in init gyro, and is also blocking.
Unread 26-03-2011, 18:57
Jogo Jogo is offline
FRC #0353 (Pobots)
Jogo is on a distinguished road
We were out of control a couple matches because of moving the robot while turning it on. This confuses the gyro, because it considers the voltage during this moment an angular rate of zero. As far as I can tell, the only safe work around is to not turn the robot on until it is still.
Unread 26-03-2011, 19:21
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
On the C++ side, it takes about 6 seconds from the time the gyro is instantiated to the time that it is done with its calibration. You can actually see the calls to the task wait function in the WPI gyro code. One idea that we have is to turn on an LED after the calibration is complete.
Unread 26-03-2011, 19:48
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
It would be fantastic if the fms had an initialization mode that runs for 15 seconds before autonomous starts.
This way the gyro and all the other sensors and need standstill calibration can be calibrated in that period.
So the robot can be turned on and any point. when the robots are all ready and aligned, They "start" the match by triggering the init sequence using the fms, countdown 15 seconds and then the match start.
Any comments on this approach for next year?
obviously it cannot be implemented this year.
-Borna Emami
Team 0x27
Unread 26-03-2011, 21:12
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
I think putting your code in the disabled loop could possibly work to have this effect?
Unread 26-03-2011, 23:37
We're considering adding a gyro for backup heading. We were thinking of putting in an LED to let us know when the calibration is complete, but we weren't sure if there's anything in LabVIEW that tells us when it's complete (i.e. how do we know when to turn on the LED?). The signal light on the robot won't start flashing until after Begin.vi is finishes, so I'm thinking that once the signal light starts flashing, the gyro calibration is complete. We'll have to test that out at the school.
As a backup, I'm considering doing it the old fashioned way - just reading the analog voltage and doing our own bias and integration.
Unread 27-03-2011, 12:52
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The "other" solution to this is to spend less time lining the robot up. Our programmers told me about this, then told me about waiting 20-30 seconds after the robot was turned on to move it, or even place a tube on it. I told them we'd be shooed off the field if we were just standing around waiting for the bot to initialize.
So our drivers eventually got lining up the 'bot down to ~10-15 seconds. Worked well enough for alignment.
GitHub
Unread 27-03-2011, 12:58
Joe mentioned above that the gyro open is a blocking call. Could you wire the output of that (or use one of those fancy flow blocks..I'm a Labview n00b ) to something that activates the LED?
Unread 27-03-2011, 14:10
Yeah, I know that now - before Joe's answer I didn't know if it was a parallel task.
As it turns out, since the gyro open is blocking, I shouldn't need to do anything. The default code flashes USER 1 LED in PeriodicTasks.vi. PeriodicTasks.vi won't run until Begin.vi completes. So... as long as open gyro is done in Begin.vi (which is where it should be), USER 1 LED will not start flashing until the gyro cal is complete. Yea for simplicity.
Unread 27-03-2011, 14:18
Vikesrock's Avatar
Happy Birthday! Vikesrock Vikesrock is offline
Team 2175 Founder
AKA: Kevin O'Connor
I just had a thought that I figured I would throw out there.
What about using a Driver Station input to trigger the Gyro Open in Autonomous Disabled? Then the gyro bias can be calculated during team introductions.
Unread 27-03-2011, 14:41
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
This is an important issue as more teams are using the gyro.
We are thinking of adding a relatively quiet but noticeable buzzer that will turn on for 8 seconds- the last 2 seconds we will use to initialize the gyro.
If the field crew is moving the robot when the buzzer sounds, they know they have a few seconds to stop moving the bot- if they don't, they at least know that they should reset the cRIO.
