Go to Post IMHO, [the driver's] job is to drive the robot. The coaches job is to monitor everything in a match that isn't your robot. - CalTran [more]
Unread 23-03-2011, 16:57
lon.bushweiler lon.bushweiler is offline
FRC #0093
lon.bushweiler is an unknown quantity at this point
Re: Distance of travel while using mecanum wheels
Team 93 is using a small omni drag wheel with encoder that is pressed to the ground with surgical tubing to determine exact distance travelled in autonomous. The gyro is also used to ensure that the robot stays properly aligned with the scoring rack.
