Go to Post if we aren't here for some wisdom...what are we here for? - Molten [more]
Unread 17-03-2011, 00:29
Onederful Onederful is offline
Onederful is an unknown quantity at this point
Distance of travel while using mecanum wheels
How do you calculate the distance the robot will travel relative to the rotations of the mecanum wheels while strafing, going forward, and a diagonal?
Unread 17-03-2011, 01:05
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
Re: Distance of travel while using mecanum wheels
If I were in a time crunch with an assembled robot in front of me I would drive a known number of rotations and then measure the distance traveled.
Queen's Applied Science '13, Applied Mathematics
Unread 17-03-2011, 01:07
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
I'll take the "going forward" part: Same as any normal wheel.
OK, somebody else take the others.
(Seriously, I agree with the "measure it" suggestion. Better than any calculation or guess.)
Unread 17-03-2011, 01:11
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
If it were me, i would use an accelerometer and gyro, to much slip in mecanums to be able to be reliable especially when you are moving in a non-forward direction
Unread 17-03-2011, 01:17
AdamHeard's Avatar
Lead Mentor
If you truly want reliable data here, you might want small, lightly loaded, unpowered wheels on the ground that are hooked to encoders.
Vex omniwheels work great for this, you can measure X with one and Y with the other.
Unread 18-03-2011, 12:16
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
As already stated, forward and backward is easy, it just acts like any other wheel here. As for strafing, this will depend on the angle of the rollers on the wheel, most will be 45 degrees, but I've seen other angles. If the rollers are set at 45 degrees then in the best case, the robot will strafe at the same rate it moves forward or backwards. Of course there will be some scrubbing losses, so it won't be optimal, but that is true or forward and reverse as well.
"History doesn't repeat itself - at best it sometimes rhymes" --Mark Twain
Unread 18-03-2011, 13:05
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
^ I can confirm this post. We did our testing in early 2010.
GitHub
Unread 23-03-2011, 16:57
lon.bushweiler lon.bushweiler is offline
FRC #0093
lon.bushweiler is an unknown quantity at this point
Team 93 is using a small omni drag wheel with encoder that is pressed to the ground with surgical tubing to determine exact distance travelled in autonomous. The gyro is also used to ensure that the robot stays properly aligned with the scoring rack.
