Go to Post Well, are comedy and sarcasm COTS items? - Karibou [more]
Unread 23-03-2011, 13:14
niteowl22 niteowl22 is offline
co-advisor, team 1091
AKA: Anne
FRC #1091 (Oriole Assault)
Team Role: Communications
niteowl22 is an unknown quantity at this point
Question Mini bot fuse question
What I need to know, is what size fuse, that the mini-bot battery pack uses, and where to purchase them.
Thanks in advance for answers!
Unread 23-03-2011, 13:23
Amehrotra Amehrotra is offline
FRC #0503 (Frog Force)
Amehrotra is an unknown quantity at this point
Re: Mini bot fuse question
Im pretty sure the fuse type is called mini blade fuse
The fuse in the stock battery uses a 20AMP fuse, Since the motors stall current is around 7 amps I would recommend putting a 5 amp fuse in there.
This way the fuse will blow before the motors blow, just be sure to have extra fuses in hand.
The Wikipedia of the Future:
http://froggypedia.com/
Team 503 FrogForce
Brandon Holley's Avatar
We got ours at the local RadioShack: http://www.radioshack.com/product/in...ductId=2102772
They're just called mini-blade fuses.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 23-03-2011, 13:26
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
You can also get the fuses from any place like Autozone, Napa, Advanced Auto.
2014 Wisconsin Engineering Inspiration Award, CIR Engineering Excellence Award
2013 Croosroads Engineering Inspiration Award
2012 BMR Judge's Award, 2011 BMR Regional Champions, BMR Motorola Quality Award, BMR Autodesk Excellence in Design Award, 2010 BMR Regional finalists; 2009 BMR General Motors Industrial Design Award; 2008 BMR Engineering Inspiration Award; 2007 BMR Rookie All-Star Award
Darrin Munter - N9SDD
Advanced Technology Services
Unread 23-03-2011, 13:28
AKA: Anne
Thank you!!! I knew this was the right place to ask for a quick answer. You people are great!!
Unread 23-03-2011, 13:35
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
these are also commonly refered to as an ATM sized fuse.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 23-03-2011, 16:06
Tuba4 Tuba4 is offline
AKA: Tom Albert
FRC #0063 (The Red Barons)
Tuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant future
Got a nice assortment box at our local Walmart with sizes from 2 amp up to 25 amp. Heavy on 7.5, 10, 15 and 20 amp sizes. Under $20.
Unread 23-03-2011, 17:20
Generator of Entropy
FRC #2973 (The Mad Rockers)
Unless you are using 2 motors, in which case you probably want to go with a 10 amp fuse since together they will draw 7 amps at full power (14 at stall)
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
With a direct-drive minibot, I was blowing 5-amp fuses. 10 Amp works but makes me nervous. Maybe there's a 7 Amp fuse.
Unread 23-03-2011, 17:30
How many climbs/matches did yours last with the 5amp?
Unread 23-03-2011, 17:33
For OUR tests, we lasted about 6 inches of vertical travel before the 5 amps popped. When our minibot deploys and hits the bar, the spinning shaft gets slowed down considerably and theres a definite current spike that occurs to get the bot moving.
We switched to 10 amps, been using the same one all competition. Our turn off switch is EXTREMELY reliable so we are less concerned about smoking anything with our system, so 10 amps may be overkill for your needs.
-Brando
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
We used 5 amps for a bit, went through a fuse a match pretty much.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 23-03-2011, 21:45
DonRotolo's Avatar
Back to humble
FRC #0832
A team in NJ was using the 7.5A fuse as a shut-off for when it hit the top, I didn't notice any damaged motors. They did blow a fuse every match though.
Unread 23-03-2011, 21:58
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
We use a 7.5 A, and replace it after every match.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 23-03-2011, 22:38
It immediately blew. Would not even start moving.
