Go to Post Not every team can start 200 teams in Canada or Hawaii because they are located in relatively dense region of teams already. This doesn't mean they can't impact their local and surrounding areas. This is where you have to be creative. - tim-tim [more]
Unread 23-03-2011, 14:35
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: CIM Motor Capacitors
Originally Posted by ProgramLuke View Post
We are indeed having issues with communications. We are using all 4 CIMS on our drivetrain but if we don't have a battery that idles around 13V We lose comms if we try to accelerate quickly. What happens is that the Dlink drops out and we have to wait for it to restart to get communications. Are other teams having issues like this and do you have any solutions?
Yes, the solution is to not accelerate so quickly. Motor noise isn't causing the problems you are experiencing, it's safe to say. What's happening is that while trying to accelerate quickly, your send out far too much current to your motors, which results in a massive voltage drop on the system. This voltage drop will cause things like the radio, and possibly Crio, to shut down. You probably either need to instead tell your drivers to be easier on the throttle, implement a software safeguard against reckless behavior, or some combination of the two.
Additionally, partially charged and old batteries just like to exacerbate the problem described above. While a new one may be capable of putting out enough current to keep the voltage sufficiently high, a bad one will surrender.
Attending: MN Duluth Regional
Unread 23-03-2011, 14:38
Originally Posted by Munter2081 View Post
We did the same thing two years ago! We were at the BMR, when a mentor from WildStang help us out.
Me?!?
Unread 23-03-2011, 15:12
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
Me?!?
It was Raul,
He said that he seen a couple of teams make the same mistake.
Blew us away, because everything was working on the test frame. When we moved everything over to Lunacy robot some how that got changed.
Lesson 1: Move over stuff one thing at a time.
Lesson 2: Take picutes before hand. Use them as a reference.
Lesson 3: Labels! What to where.
You can learn a lot from making mistakes - even more from fixing them.
2014 Wisconsin Engineering Inspiration Award, CIR Engineering Excellence Award
2013 Croosroads Engineering Inspiration Award
2012 BMR Judge's Award, 2011 BMR Regional Champions, BMR Motorola Quality Award, BMR Autodesk Excellence in Design Award, 2010 BMR Regional finalists; 2009 BMR General Motors Industrial Design Award; 2008 BMR Engineering Inspiration Award; 2007 BMR Rookie All-Star Award
Darrin Munter - N9SDD
Advanced Technology Services
Unread 23-03-2011, 16:23
A healthy battery can put out enough current to trip the main breaker without browning out the cRIO.
Unread 23-03-2011, 17:56
Not exactly, the Crio power supply on the PD will continue to output 24 volts until the battery voltage falls below ~4.5 volts. The analog jumper in module 1 monitors the battery voltage and when it falls below 5.5 volts, the Crio output is inhibited to allow the battery voltage to rise with no load. Sort of a no-battery backup battery.
Unread 23-03-2011, 18:02
How much current does it take to trip the main breaker.
Unread 23-03-2011, 18:09
WPI Freshman
AKA: Alex
A lot. It can withstand 600 amps for a second, if I recall. I'll try to find the curve.
In a few seconds the main breaker would take ~720 amps to trip. The NP18-12 battery is only speced at 500 amps out into a short circuit at which point (at full charge), it is dropping 5.5 volts just across the internal resistance of the battery ignoring any other losses internal to the battery. 500 amps will drop another volt across the #6 wiring ignoring the resistance of the main breaker, Anderson connector, crimps and terminals.
Unread 23-03-2011, 18:32
If you have a link to the spec for that could you post it please.
So it is. Interesting. The 2009 battery spec says 720 amps for 5 seconds.
Unread 23-03-2011, 19:24
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
Team Role: Driver
bobosalad is an unknown quantity at this point
What are you running besides your four cims? Did this problem show up during Duluth? If it did, you guys managed it pretty well. After the communication dropped, were you ever able to get it back?
Spartans, Prepare for GLORY!
Unread 23-03-2011, 21:21
ProgramLuke's Avatar
ProgramLuke ProgramLuke is offline
Captain
AKA: Luke
FRC #2169 (KING TeC)
ProgramLuke is an unknown quantity at this point
We are also using 2 of the smallest banebot's, a window motor, and the compressor.
2012 Inaugural Minnesota State High School League State Champions
2012 Galileo Division Semifinalists
2012 Wisconsin Regional Finalists
2012 Wisconsin Regional Entrepreneurship Award
2012 Lake Superior Regional Chairman's Award
2012 Lake Superior Regional Champion
2012 Lake Superior Innovation in Control
2011 Championship Imagery Award
2011 Championship Archimedes Quarterfinalist
2011 Minnesota 10000 Lakes Finalists
2011 Lake Superior Regional Chairman's Award
2011 Lake Superior Finalists
2010 FTC World Championship Finalist
2010 FTC World Championship Edison Division Champion
2010 Minnesota 10000 Lakes Regional Chairman's Award
2009 Minnesota North Star Regional Chairman's Award
2008 Wisconsin Regional Finalist
2007 Wisconsin Regional Champion
Unread 23-03-2011, 22:16
The main breaker sheet is on CD already. You just have to search to find it. The actual spec is 600% over current for a few seconds and several minutes at 200%.
Unread 23-03-2011, 22:28
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
The main circuit breaker is Terminal Supply's CB3-SM-120, which is actually a Cooper Bussmann 18X series breaker (probably a 185120F). Their characteristics are here (from the manufacturer, see page 32 printed/34 PDF), or here (directly) or here (for an older spec sheet from FIRST).
According to that diagram, some breakers may last for up to 3 seconds before tripping at 720 A.
Last edited by Tristan Lall : 23-03-2011 at 22:32. Reason: Might as well add the phrase "main circuit breaker", so the search can find this later....
Unread 23-03-2011, 22:32
The Terminal Supply P/N CB3-SM-120 that AndyMark markets as their P/N am-0282 is spec'd by the manufacturer Cooper Bussman at 440 amps nominal for 5 seconds.
[edit] I see Tristan beat me to it. Nominal 440amps, range 352..528 amps for 5 seconds.[/edit]
Unread 23-03-2011, 23:42
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Does this alarm anyone?
We're using this thing as a switch, not a breaker.
-- Marshal Horn
