Go to Post "The reason we struggle with insecurity is because we compare our behind-the-scenes with everyone else's highlight reel." - davidthefat [more]
Unread 23-03-2011, 18:03
MrHance's Avatar
MrHance MrHance is offline
Long Distance Mentor
FRC #0647 (Cyber Wolf Corp)
MrHance has a spectacular aura aboutMrHance has a spectacular aura aboutMrHance has a spectacular aura about
Re: pic: Lamp_Switch
"I think I may have exaggerated, but it's mostly a question of interpretation; when I hear the term "common household light switch", I think of the typical light switch found as a part of a house that controls a light in the house. A desk lamp switch just doesn't seem to me like a "household light switch". I know there are questions in the Q&A about the non-slip pad, and the GDC has ruled that only materials marketed as a pad with non-slip properties are allowed. This lamp switch isn't really marketed as a common household light switch."
In reference to the above comment. I would refer that the switch in question is indeed used in household application as it is used in some light fixtures in the bathroom, bedroom and kitchen (on the exhaust hood above the stove). This would make it a household common light switch.
Past observations living in many apartments and house over the last 40 years or so.
Unread 23-03-2011, 18:08
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I bought four of these from Home Depot Yesterday.
The Back of the packaging says "For lamp and lighting fixtures" - I'm pretty sure it's a light switch.
-Dustin Benedict
Unread 23-03-2011, 18:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
There should be no "this is really pushing it, but we'll allow it" with the rules. A switch is either for a household lamp/light or isn't. It's not a matter of anyone's opinion. This switch is. See the description.
http://www.amazon.com/gp/product/B000HEFDMY
Also, see Team Update 12.
Unread 23-03-2011, 18:15
Carlinh's Avatar
Carlinh Carlinh is offline
FRC #0027 (Team RUSH)
Carlinh is an unknown quantity at this point
I know of 1 team that used this type of switch at Waterford and was warned not to show up at their next competetion with the same switch unless they could show that is was a light switch and not a lamp switch!!! So beware!!
Unread 23-03-2011, 18:21
Guys,
We inspect to the rules and interpretations given us by the GDC. Our direction is in TU#12...
Therefore, “light switches” permitted on the MINIBOT are not confined to those used in wall mounting boxes; anything sold as a “light switch” for household use is allowed.
If it says "lightswitch" on the box, card, bin, or website and you can show that the label stating "lightswitch" matches the switch you are using, we must pass it.
Unread 23-03-2011, 20:29
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
Our team's minibot used a similar switch. We passed inspection at the NYC Regional. We brought the packaging that said something like "Toggling lamp light switch" just in case, but we didn't have any issues with the inspectors.
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
Unread 23-03-2011, 23:50
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
Team 2057 used this exact switch.. its with the "special switches" at home depot. It was successful for our minibot but BE CAREFUL.. it does take a lotta force to push it in.
Best of luck
2057
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 24-03-2011, 01:05
El Geffe's Avatar
El Geffe El Geffe is offline
Mars here I come
AKA: Geoff
FRC #0060 (Bionic Bulldogs)
Team Role: Driver
El Geffe is an unknown quantity at this point
I glad this is deemed acceptable, because as TheOtherGuy said we did have some difficulty proving that several parts of our minibot were legal, including this exact light switch and some non-slip pad we usually use as tire tread.
Really? We didn't have any trouble pushing it in. In fact' we hit the top so hard once it bust the switch right out of the plastic casing.
2011 - AZ Regional Finalists with 2449 and 1165
2011 - Vegas Champions with 2984 and 987
2011 - Championships ?
Unread 24-03-2011, 12:10
clayman's Avatar
clayman clayman is offline
AKA: Clayton
FRC #3175 (Knight Vision)
clayman is an unknown quantity at this point
Instead of using a switch, we just used 5A fuses on the minibot - it's a bit of a pain to switch them each time (they blow as soon as the motors try to drive through the top of the pole), but we don't have to deal with any... switch
Unread 24-03-2011, 13:03
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
How long would it take for a 5 amp auto-reset fuse to reset? I wonder if that's a possible solution to ensuring the tower is triggered...
EDIT: then again, it needs to be an equivalent type fuse to the Tetrix one. Oh well...
Unread 24-03-2011, 22:17
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: pic: Lamp_Switch
good find, and good post. will certainly help some teams. Any idea how much force is needed to push the switch on/off?
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 25-03-2011, 23:18
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Wow! What a great idea! Way to think out of the box!
Steve
Unread 25-03-2011, 19:17
PayneTrain's Avatar
PayneTrain PayneTrain is online now
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I can't speak for the team truthfully, but 88 appeared to be using that exact switch on their minibot in Baltimore.
If you are a direct drive under 5 pounds, you should be dandy.
Unread 29-03-2011, 15:02
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Yes, team 88 uses the same toggling light switch (either from Home Depot or Lowe's). We can also confirm that it is possible to hit the top so hard that the switch mechanism is driven through the back of the switch housing. We added a bolt as a mechanical stop to prevent that from happening.
Unread 25-03-2011, 23:55
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
In Seattle and Portland similar switches were/are on many minibots. That passed inspection w/o issues.
There was a team that had a universal headlight switch (along with some resistors) but we got that changed before inspection.
