Go to Post it's shadows and fog and stormy skies and a reminder that things are rarely black and white but instead, the places in between. - MissInformation [more]
Unread 23-03-2011, 13:08
Check joysticks and I/O module before each match
I've seen a few reports of joystick and cypress I/O module problems.
Originally Posted by Adam Freeman View Post
2054 had some type of computer issue, where it would not recognize their joysticks... so they set still during the entire first match.
Originally Posted by Mark McLeod View Post
We see a lot of this type of behavior (lack of controls) when a bunch of stuff is plugged into a single USB hub and it isn't getting the power it needs to run everything.
Originally Posted by Joe Ross View Post
Here's a list of issues that caused teams to not work on the field at San Diego:
There were at least 3 cases where joysticks did not work on the field.
With sleep mode there is a possibility that the USB joysticks/Cypress can get resorted and is something to check/verify when you wake it up.
While statistically, the chances of a problem are very low, it's really easy to check that your joysticks / I/O module are working before a match (takes 10 seconds) and can save your match.
Change to the diagnostics tab on the driver station software. Verify that there is a green light next to each joystick that is connected, and to the I/O module (if connected). Press a button on each joystick and verify that the green light changes to blue on the appropriate joystick. If you have the I/O module, press a button and make sure that the I/O light changes to blue.
If the joysticks aren't in the right order, go to the setup tab and drag them to the correct order. If the joysticks don't light up, press F1 to re-enumerate them, or unplug your USB hub and plug it back in. If the I/O module isn't detected or isn't working, unplug it and plug it back in.
Problems can be worse if your classmate has very low battery (make sure it's plugged in in the pits), or if you have a lot of USB devices that are overloading the power requirements. The Cypress board should be plugged in to the classmate directly, since it uses a lot of power. I've also seen one case each of a bad hub or a bad joystick.
Unread 23-03-2011, 13:21
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Check joysticks and I/O module before each match
We've also had some minor joystick issues, mainly with people yanking on the cables / wrapping the cable around the controller way too tightly. Now one of them reads 0.5 at the idle position. We had to swap the driver/operator controllers, since it was happening on the driver side and the operator controls don't use the joystick.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 23-03-2011, 14:56
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
We had the same thing happen to us. We started checking our joysticks every match. Luckily we won the match in autonomous, so nothing too bad happened other than our scouting data looked bad for us.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 23-03-2011, 15:00
Jared Russell's Avatar
Taking a year (mostly) off
Additionally, we had an issue last year where one of the USB ports on the Classmate was damaged enough that jiggling the joystick cables caused intermittent connections. Note that the Driver Station automatically disables your robot if it detects that joysticks are removed while you are enabled!
Unread 23-03-2011, 15:08
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We found last year that Cypress comm issues are often caused by the Cypress driver on the laptop end - Apparently it can sometimes hang when coming out of standby, and there is absolutely no way to restart it (with the locked-down driver account we had last year), without restarting the computer. Since the Cypress board was vital to our robot, we would start up the Classmate two to three matches ahead of time, just in case we had to reboot. It drained the Classmate battery, and was terrible, so we were often rushing to keep the laptop charged because of the lack of power on the field.
I haven't heard of any fixes to this issue, although the new rule allowing any laptop would make it seemingly easier to reload the Cypress driver without rebooting.
Related note: Don't boot the laptop unless all of the joysticks are centered. At Kettering, in Qf1-2, we got stuck on the rack because our joysticks weren't centered, resulting in a near inability to drive.
Kettering Motorsports
Unread 23-03-2011, 16:07
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Is there a way to rename joysticks? For example we use 2 identical joysticks for drive. I have a feeling that there might be a way through the Windows joystick properties menu but I have no joystick to play with at the moment.
Unread 23-03-2011, 18:05
spacepenguine spacepenguine is offline
AKA: Ian Hartwig
spacepenguine is an unknown quantity at this point
We also had issues with joystick/cypress board connectivity at Waterford. It was rather simple to unplug/replug them in and restart, but it cost us 2 matches at Waterford. Checking the green light on the I/O tab and a blue light for the joysticks in the diagnostics tab when a button is pressed has become part of our pre-match routine.
2008-2011: #226 - The Hammerheads
Unread 23-03-2011, 22:54
bstrong1218's Avatar
bstrong1218 bstrong1218 is offline
Brandon
AKA: Brandon
FRC #3344 (Robocopz)
bstrong1218 is an unknown quantity at this point
Good advice. Our Classmate didn't show the Cypress board during our last ditch effort in quarterfinals at Peachtree so we lost the ability to deploy our minibot.
We knew about the issue before the match started, but didn't have time to reboot the computer.
Checking on the Cypress board definitely belongs on the pre-match checklist. Might not hurt to check settings such as pulled high/low... we had an issue with that setting switching back to the default which caused our minibot to deploy into our arm mid-match.
Unread 23-03-2011, 23:01
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Our drivers had to quickly swap joysticks in one match. the driver started with one side of the robot and the arm, the other driver had the other side of the robot. They checked everything thoroughly from then on.
2016 Central Illinois Winner. Curie Division finalist
Unread 24-03-2011, 03:53
Nope. The name you see is the name the device reports for itself. The best you can do is press a joystick button and verify that the correct one turns blue on the Driver Station.
Unread 24-03-2011, 08:19
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
Ditto that for us at Pittsburgh. Tried everything *except* rebooting the Classmate - natch. We've used the same setup for three years now so I'm surprised we didn't make that mistake sooner.
Unread 24-03-2011, 19:30
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
During the Lake Superior regional, on one of the last qualification matches, a similar incident happened to us. I'm not sure if it was do to that stupid stop button causing an overload earlier on the USB ports (it seems like those lights draw wayyyy too much power).
No matter what I tried doing with our Joystick and controller, be it unplugging them or whatnot, the computer we were using absolutely refused to recognize that they were plugged in, and the driver station thus didn't see them either. I had to reboot the whole thing after the match to get it working again. Needless to say, we sat there watching our team get creamed.
Attending: MN Duluth Regional
