Go to Post 22 motors? Challenge Accepted. - gyroscopeRaptor [more]
Unread 23-03-2011, 20:36
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
Re: nxt minibot
176's first minibot has an NXT brick on it. It was used because the person making the minibot did not know how to wire limit switches and household switches to change the polarity and/or stop the current to the motors as he desired. That minibot weighs 7 pounds now, and climbs in 9 seconds.
I would advise against using the NXT. You don't need it. If you've created a minibot that is so complicated it needs an NXT brick, you've done it wrong.
Our second minibot is 2 motors, with direct drive to the FTC wheels, and a batter strapped to the back with a few switches to control the polarity and on/off. This minibot weighs about 3 pounds and climbs in roughly 3 seconds. It's not a super fast minibot, but it took less time to make than the far more complicated NXT bot, and is much faster.
FRC 176 - Aces High - 09-12 - Student
FRC 229 - Division By Zero - 13-14 - "Mentor"
FRC 2170 - Titanium Tomahawks - 17-Now - Mentor
