Go to Post they just build excellence and silently wait to deploy their creation on the unsuspecting masses - Koko Ed [more]
  #31   Spotlight this post!
Unread 21-03-2011, 14:23
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Lessons learned in all weeks.
Originally Posted by Arefin Bari View Post
I believe 175 human loads as well...
They human load but they can pick up off the ground, just it isn't worth it according to a member I spoke to.
1058 PVC Pirates 2016 - xxxx
  #32   Spotlight this post!
Unread 21-03-2011, 20:45
BIGWILLI2081's Avatar
BIGWILLI2081 BIGWILLI2081 is offline
FRC #2081 (Icarus)
BIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of light
just my $0.02:
- As previously stated, minibots are a game changer
- Be careful if there is a defender on your end. If you get pushed into the opposing alliance's lane, it is a penalty on you and the defending bot only gets one if the action is deemed intentional. My strategy for this is to not come out of your home zone unless you know you've got the defending robot beat.
- There are many strategies to Logomotion. If it seems the team you're going up against can outscore you, or has only one minibot when you have two, try starving the field. It will produce lower scores for both teams, but if you get more minibots scored than the other alliance (and have successfully starved the field), it is likely you will win.
- Don't underestimate the third alliance pick. They have to be a good at defending and herding tubes for your alliance to be successful.
- Lastly, beware of over inflated tubes. The rules about tubes changed after the build season and they are now inflated to 7-8 inches instead of just being 7. My team had to cut off some of our claw to fit in the boundaries at the beginning of the match, but it seemed the inflated tubes (especially the squares) were easier to pick up, so it was a blessing in disguise.
2011 Boilermaker Regional Champions
2011 Boilermaker Motorola Quality Award
2011 Boilermaker Autodesk Excellence in Design Award
2010 Boilermaker Regional Finalists
2009 Boilermaker General Motors Industrial Design Award
2008 Boilermaker Engineering Inspiration Award
2007 Boilermaker Rookie All-Star Award
  #33   Spotlight this post!
Unread 24-03-2011, 11:02
racesick222's Avatar
racesick222 racesick222 is offline
it can be done
AKA: race
FRC #0222 (tigertrons)
racesick222 will become famous soon enoughracesick222 will become famous soon enough
Teams have to learn not to set up at the min i bot tower with 30 some seconds left. Complete a logo or just place a piece on the rack you will get back to the tower in time for most team.
2011 Boston Regional finalist (thanks 125 and 2648)
2012 Chestnut Hill District finalists (thanks 4342 and 2180)
2012 Mount Olive District Champs (thanks 25 and 3929)
2013 Mount Olive District Champs (thanks 11 and 3340)
2013 MAR Championships finalists (thanks 11 and 1403)
  #34   Spotlight this post!
Unread 24-03-2011, 13:05
Defense. If you place that piece, your opponent will get between you and the tower, and then you won't get to the tower. If you're on the tower at 30 seconds, they can hit you for 15 seconds, debate whether to back off for 5 seconds, but if they hit you after that, they get a red card. If you're placing a tube before running back, they get between you and the tower, and you can get a pinning penalty. Worse, if you try to ram your way through, you need to be careful not to hit your opponent at their tower, because then you get the red card.
330 learned that the hard way in Arizona last weekend.
  #35   Spotlight this post!
Unread 24-03-2011, 13:38
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
The sum of the parts do NOT equal the whole.
In alliance selection taking critical points away from other alliance can equal big points for you.
This means minibot and autonomous monopolies can determine wins and losses.
Come Einstein though, I expect that minibot and autonomous monopolies won't exist. What will be critical on Einstein is being able to leave your best robot (not robot + minibot) at the rack to finish capping those last critical tubes. I predict that unless there are huge upsets in the elims, the 6 points captured from each of the lower level rack will differentiate the winners from the losers.
but for now minibot and autonomous makes the difference. You have to have a monster of a robot to offset not having a minibot (148 being one of the only teams able to accomplish this), so if you don't have a minibot, unless you are one of the best, you are in trouble.
same is true for autonomous. Having a consistent autonomous is very valuable.
reliability > potential for everything (IMO)
  #36   Spotlight this post!
Unread 24-03-2011, 14:53
torihoelscher's Avatar
torihoelscher torihoelscher is offline
Wow I feel old
AKA: Princess Leia
torihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant future
Send a message via AIM to torihoelscher
Autonomous and MiniBot very important.
Autonomous that doesnt go backwards!!! LOL
Tori Hoelscher
FLL
FTC
FRC
"May the [mass x acceleration] be with you"
"Aren't you a little short to be a storm trooper?"
Alumni of Team 79 Krunch.
  #37   Spotlight this post!
Unread 24-03-2011, 20:53
Eagleeyedan's Avatar
Eagleeyedan Eagleeyedan is offline
C.O.R.E.; We build on each other
AKA: Daniel C.
FRC #2062 (C.O.R.E. 2062)
Eagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the rough
Originally Posted by theprgramerdude View Post
Floor-loading is the key to taking home the gold for the tube part of the game --- no exceptions. If you can reliably pick stuff up off the floor, you save tonnssssssssss of time compared to driving to the pocket. It's even nicer when you can grab tubes in mid-air as they're thrown by the opposing alliances human player.
Grab tubes in mid-air? I've never seen a team do that. How would that be possible?
Former Driver and Safety Captain of team C.O.R.E. 2062 (Community of Robotic Engineers)
2015: Wisconsin Regional- Champions, Industrial Safety Award
Midwest Regional - Champions, Industrial Safety Award, Industrial Controls Award
2014: Midwest Regional - Judges Award
2013: Lake Superior Regional - Champions
2012: World Championship - Industrial Safety Award, World Finalist for the Autodesk Award
2011: Wisconsin Regional - Website Award 10,000 Lakes Regional - Innovation in Control, Safety Award
2010: World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
10,000 Lakes Regional - Regional Champs, Entrepreneurship Award
Wisconsin Regional - Entrepreneurship Award, Industrial Safety Award
2009: WI Regional- Quality Award, Industrial Safety Award
10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008: World Championship - Industrial Safety Award,
Wisconsin Regional - Champions, Industrial Safety Award
  #38   Spotlight this post!
Unread 24-03-2011, 21:20
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Something very important: At our regional, at least, tower bases got dented. They're made up of about 12 different pieces with radial support structures between each piece (look at the field drawings), and by the end of our regional every single one of them (on all four towers) was dented inward. This made our deployment lining up mechanism mess up. Make sure you account for some denting, especially in the bottom half (the top part of the pieces weren't so bad).
