Go to Post Let's all try to get along, it isn't that complicated. - Joe Johnson [more]
Unread 24-03-2011, 17:47
ADTRavenger3585 ADTRavenger3585 is offline
FRC #3585
ADTRavenger3585 is an unknown quantity at this point
breaking the minibot/ controled descent
what is the best way to safely stop the minibot at the top of the pole or put it in a controled descent. please give me a good explanation. danke.
-ethan and 3585
Unread 24-03-2011, 18:43
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: breaking the minibot/ controled descent
See this thread http://www.chiefdelphi.com/forums/sh...threadid=93876
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 24-03-2011, 18:46
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Most methods involve increasing friction on the poles greatly. That can be done when the normal force on the pole by the wheels is greater. However, when doing that it usually makes it slower. Not saying the normal force and friction is completely bad, but theres a fine line.
In all honesty, your minibot should be fine if it falls back down.
If your're really concerned, put foam or some cushioning support on your deployer so that when it comes back down it softly lands into that.
Hope This Helps,
-Duke
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 24-03-2011, 19:57
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
-ethan and 3585
The best way, we found, for a controlled descent, is to make the motor act as a brake on the way down.
To do this you need to connect the positive pole of the battery to both electrical connections of the motor, during descent. Use a light switch that gets switched when the minibot hits the top to do this.
Basically, have the lightswitch change the connections on the motor from + and - to + and +.
___________________
- Tennyson, Ulysses
Unread 25-03-2011, 07:22
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Actually, it has nothing to do with connecting the motor to (+) but rather, shorting the leads to the motor so that as it backdrives down the pole it acts as a generator. With the dead short on the "generator output" it resists rotation.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 25-03-2011, 20:20
TEE's Avatar
TEE TEE is offline
FRC #0201
TEE has a spectacular aura aboutTEE has a spectacular aura aboutTEE has a spectacular aura about
haha, the title of this thread confused me at first... you said "breaking" instead of "braking"
Unread 25-03-2011, 21:38
tdramble tdramble is offline
FRC #1014 (Bad Robots)
tdramble will become famous soon enough
We implemented a circuit that switched the motors from driven to "braking" via a short when it reaches the top, here is a video: http://www.youtube.com/watch?v=KEXraq_Tmy0
Unread 25-03-2011, 22:07
ROBOTS!'s Avatar
ROBOTS! ROBOTS! is offline
Minibot Master
AKA: Ian M.
FRC #1504 (Desperate Penguins)
ROBOTS! is an unknown quantity at this point
we broke 3 gearboxes on our minibot from it hitting the bottom when it came back down. A little surgical tubing as padding works nicely!
Unread 25-03-2011, 23:33
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Correct it is turning the motor into a generator that creates the dynamic braking effect.
Most teams short it via the (-) side of the circuit rather than the (+) side, though both ways will do the same thing.
Unread 26-03-2011, 18:08
Mad Scientist
AKA: Me
FRC #2040 (DERT)
My understanding (and I may be wrong, it's been a while since I'ce studies regenerative braking) was that connecting the (-) sides together dissipated the energy as heat in the motor while connecting the (+) to both sides would dissipate the energy by recharging the battery. Am I incorrect in this? and if I'm not wouldn't it be better not to heat an already heated motor?
___________________
- Tennyson, Ulysses
Unread 26-03-2011, 19:28
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Regardless of which side you connect, the battery is not part of the completed circuit and thus no current flows in or out of it. All energy dissipation occurs in the motor and the wiring/components that are shorting the leads.
Unread 28-03-2011, 08:42
Daniel,
By shorting the motor leads together, you cause all generated currents to flow in the short and no where else. It does not matter whether the the positive or negative lead of the battery is connected at all. No current will flow through the battery when the motor leads are shorted. This method is identical to the the "brake" mode on either the Victor or Jag. The amount of current generated and the amount of braking action is RPM dependent. The faster the motor is spinning the more braking is evident.
