Go to Post What is it about inefficient design and operation that either pushes the envelope or deserves to be awarded? - Madison [more]
Unread 24-03-2011, 18:41
ADTRavenger3585 ADTRavenger3585 is offline
FRC #3585
ADTRavenger3585 is an unknown quantity at this point
resistors?
can resistors be used on the minibot?
Unread 24-03-2011, 18:43
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Re: resistors?
Nope, they are not listed in the allowable parts spelled out in <R92>
Unread 24-03-2011, 19:14
FRC #3585
Re: resistors?
well the parts list says nothing about electronic components. the rules dont even address them.
Unread 24-03-2011, 19:32
nitneylion452's Avatar
AKA: Joe Lee
Re: resistors?
<R92> The following items are the only permitted materials for use on the MINIBOTS:
A. TETRIX components that are not
in violation of any other rules,
(Tetrix components are listed in
Approved Tetrix Parts at
www.usfirst.org/frc/competitionma
nual),
B. no more than two motors (PN
W739083/W739023) and an
unlimited number of Tetrix
servos),
C. no more than one 12V
rechargeable NiMH battery pack
identical to those supplied in the
FTC kit of parts (PN W739057)
except the 20A fuse may be
replaced with an equivalent type
of lower amperage,
D. No more than one HiTechnic DC
motor controllers,
E. No more than one NXT controller
with the Bluetooth functionality
disabled,
F. Polycarbonate,
G. Polycarbonate glue,
H. Raw welding rod, aluminum
sheet, 90° angle, u-channel, tube,
bar, that is not sold in preperforated or pre-punched form.
I. rivets,
J. non-metallic rope or cord,
K. wire nuts, solder, and crimps,
L. cable ties,
M. limit switches,
N. no more than two common
household light switches,
MINIBOTS will be inspected for the volume constraint by being placed in a five-sided
box with internal dimensions of 12" x 12" x 12". If the lid (the sixth side of the cube)
does not seat properly, the MINIBOT does not pass this part of the MINIBOT
inspection.
If an observation is made that another team’s ROBOT may be in violation of the robot
rules, please approach FIRST officials to review the matter in question. This is an
area where Gracious Professionalism is very important© FIRST 2011 FRC Game Manual, Section 4 – The Robot, Rev L Page 31 of 34
O. electrical hookup wire,
P. non-slip pad,
Q. PVC or CPVC pipe and fittings,
R. PVC cement or cleaner,
S. Mechanical fasteners (e.g.
screws, bolts, etc),
T. Loctite or similar thread-locking
product,
U. Rubber bands,
V. Surgical tubing,
W. Electrical tape and shrink tubing,
X. PWM extension cables,
Y. Universal security clips to hold
the PWM connectors together,
Z. Hook and loop fastener (may not
be used as tape),
AA. Magnets,
BB. NXT compatible sensors and
related connectors/cables,
CC. Grease, and
DD. Non-functional decorations.
Ergo, they cannot be used.
Unread 24-03-2011, 19:51
DonRotolo's Avatar
Back to humble
FRC #0832
Re: resistors?
I was under the impression that motors, batteries, switches, wire, fuses, etc were all electrical components.
Unread 24-03-2011, 20:25
Re: resistors?
The first line says, in effect, "If it's not on this list, you can't use it." Or, to put it another way, "If it's not permitted, it is prohibited, and here's the 'permitted' list".
Unread 24-03-2011, 21:26
billbcc91 billbcc91 is offline
AKA: Bill Phillips
FRC #2960
billbcc91 is on a distinguished road
Re: resistors?
If only. I'd love to replace that big heavy battery with a 2 oz ultracapacitor. Alas, it would not be legal.
Would it be worth putting in an official Q&A as to whether a resistor extracted from a legal component would itself be legal to use? I don't know which components might have resistors in them. My guess is the answer would be no, but you don't know for sure until you ask. Of course do a search of the Q&A before you ask...
Unread 25-03-2011, 02:56
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: resistors?
The bigger question is why you would want to use resistors on the minbot, do you want a slow bot? Shunting the motor leads together will make it act as a dynamic brake to slow the descent nicely. The kop limit SW or a household 3 way SW will do it. Diagrams on how to wire it are all over CD. If your bot stays at the top of the power you can use a 4 way SW to reverse 1 motor and put the other in brake mode.
Unread 25-03-2011, 10:02
FRC #3585
Re: resistors?
the idea was to wire a resistor into a DPDT switch to control the descent. seeing as resistors are apparently prohibited we just used electrical hook up wire and poly carbonate to make our own resistor. nothing illegal there.
Unread 25-03-2011, 10:13
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Re: resistors?
Early on in minibot testing we found that if you switched a 4 ohm resistance in series with the motors it slowed the motors and the mini would slowly decend. It also only required a simple lamp switch. We ended up using limit switches and back emf because of "is it legal' issues
Unread 25-03-2011, 23:03
Mr V's Avatar
FRC #5588 (Reign)
Re: resistors?
Are you driving down the pole? If you are braking down the pole resistors will actually speed up the descent.
Unread 28-03-2011, 08:47
Re: resistors?
Although this last part would be using legal parts, it is not needed. Simply short the motor leads to descend slowly.
Bill,
Remember that you would need to supply ~10 amps for two seconds to be sure your minibot would make the top. Could your super cap deliver that constantly over the two seconds?
