Go to Post Parking Lot T-Shirt Bootleggers are NOT approved suppliers - Rich Kressly [more]
Unread 24-03-2011, 22:41
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Walking Encoder Values
Can you use a multi-turn POT instead?
Unread 24-03-2011, 23:14
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
The optical encoder comes with a centering tool and a disc spacing tool. If you follow the instructions correctly in using those tools, you should not have any problem. We have a student that did not use those tools when assembling the encoder. He pressed the optical disc all the way down and ended up scratching it. So our autonomous acted strangely. After scratching our heads for a while, I finally pulled out the encoder and examined the disc and found the problem. Once we replaced the disc, everything worked fine.
Unread 24-03-2011, 23:26
pfreivald's Avatar
AKA: Patrick Freivald
Are you kidnapping my students and making them install sensors on your robot?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 25-03-2011, 03:14
mikets's Avatar
Software Engineer
Is it why we keep losing our games?
Unread 25-03-2011, 07:54
Jared Russell's Avatar
Taking a year (mostly) off
My suspects would be, in order:
1. Mechanical slippage between the encoder and the shaft whose rotation it is measuring (you seem fairly sure that this isn't the issue, and I believe you, but in general it is the first/easiest thing to check)
2. Improper spacing between the optical disc and the encoder circuitry. Use a spacer tool when installing the disc.
3. A "smudge" (fingerprint or scratch) on the disc that causes one of the photoreflectors to miss a count or two per revolution. Easiest solution: try another encoder disc.
4. EMI/wiring problem.
5. Code issue. Your code doesn't ever reset the encoder, does it?
6. An absurd pulse frequency (too high of a CPR on the encoder given the speed of the shaft it is measuring). However, in the cRIO era, you need to be well into the tens-of-thousands of pulses per second before this would be an issue, so it is unlikely.
Unread 25-03-2011, 10:46
Bryany's Avatar
Bryany Bryany is offline
FRC #1094 (Channel Cats)
Bryany is a jewel in the roughBryany is a jewel in the roughBryany is a jewel in the roughBryany is a jewel in the rough
This might not be what's causing your problems, but on our robot, the encoder would be missing ticks off and on; it would read for one second, then it would pause, then it would read some more, and so on. The encoder was plugged in all the way, but we found that the problem was because the wire was going into the encoder at an angle. (that the wire coming off at an angle was pulling the encoder out of a proper connection) We taped the wire so that it comes out straight and haven't had any problems since.
Unread 25-03-2011, 14:06
pfreivald's Avatar
All wires should have a strain relief!
Team 1551
I write books, too!
