Go to Post Ice cream is an iterative process. - JVN [more]
Unread 24-03-2011, 23:41
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
VxWorks6x
ah well, we've been using another laptop for programmming so far and now a mentor has it with him while I have somthing that is notorious for not working.
Windriver works. however, i can't connect with the target console. I went though the default for making the vxworks target console, and it won't work.
ip addresses for laptop = 10.24.5.9, 10.24.5.5 = crio in case any want to know by tether.
anything, anyone?
Unread 24-03-2011, 23:51
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: VxWorks6x
IIRC, the cRIO ip address should be 10.24.5.2 and the laptop should be 10.24.5.6
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 25-03-2011, 00:00
kws4000's Avatar
AKA: Krazy Karl
Re: VxWorks6x
That might help. I'll check it tomarrow.
Anyone else have any other ideas, more than welcome.
EDIT: IP change helped, but didn't fix it. I have some pics of errors now.
In the meantime, my eternal gratitude to 2474 and their programmer who reconfigged his laptop just for us so that we could send new code to our bot.
ID:	10481  Click image for larger version
Unread 28-03-2011, 18:03
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: VxWorks6x
Judging from the screenshot, it looks like you're running Windows XP. This isn't 64-bit is it? The WRS workbench is somewhat finicky when running on 64-bit platforms.
The next step in debugging is to make sure that you can see the cRIO via the network. Open a CMD box on your XP and issue a "ping 10.24.5.2" to see if you get a response. If not, then you do not have connectivity established. Use "ipconfig" from the CMD box to verify that the IP address is set to what you think it is. Anything on the 10.24.5.x net (except 10.24.5.2) should be fair game. Also verify that your subnet is set to 10.0.0.0. Finally, make sure that you're not running some sort of firewall software like Norton or Mcafee as these will block the ports you're trying to get to.
HTH,
Mike
Unread 29-03-2011, 08:01
kws4000's Avatar
AKA: Krazy Karl
Re: VxWorks6x
XP, running on Intel Centrino Duo inside a Lenovo. Not sure about Bit-size though.
no security software at all, it doesn't connect to internet because we don't use it for that
ping works, as does reimaging
and i'm pretty sure the subnet should be 255.0.0.0
Unread 29-03-2011, 23:06
Software Mentor
AKA: Mike Anderson
Re: VxWorks6x
Quite right on the subnet. OK, we've seen similar problems that were taken care of by copying the subdirectory of a working version of Workbench and copying it over the directory of a non-working version. That seemed to fix the problems. Alternatively, if your XP is 32-bit, then there may have just been an error in the installation. You might just try to reinstall and see if that fixes the problem.
Good Luck,
Mike
Unread 30-03-2011, 08:57
kws4000's Avatar
AKA: Krazy Karl
Re: VxWorks6x
seeing as how the season is over, i'll try it whenever I get the chance.
Thanks, yall.
