Go to Post I'm looking forward to January when things will slow down some! - Foster [more]
Unread 25-03-2011, 13:38
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
pic: Twisted Hex Shaft
Unread 25-03-2011, 13:50
Racer26 Racer26 is offline
Re: pic: Twisted Hex Shaft
Impressive. A harsh reminder of the kind of force that FRC bots exert.
Unread 25-03-2011, 13:54
Jared Russell's Avatar
Taking a year (mostly) off
3/8" diameter, 2024 aluminum?
I'm curious to know just how much torque that took...
In 2008, our arm was able to rotate the keyway of a piece of hardened 1/2" steel keyshaft almost 90 degrees. It's impressive how an FRC robot can destroy itself!
Unread 25-03-2011, 14:14
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
waht kind of aluminum is the turnbuckle?
Unread 25-03-2011, 16:25
rahilm's Avatar
AKA: Rahil Mehta
1/2" 7075, which is why we were pretty surprised.
Not sure the alloy, but it was some small diameter (bad idea in hindsight)
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 25-03-2011, 16:31
Andrew Y.'s Avatar
FunYun
AKA: Andrew Yun
FRC #2415
gotcha 7075 was the number iw as looking for. Just to be nosey it wasnt 7075 -0 right?
Unread 25-03-2011, 16:48
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I've never seen Al hex in anything other than T6
2001-2004: Team 100
2006-Present: Team 254
Unread 25-03-2011, 16:56
Brandon Holley's Avatar
Wow, that is quite a failure for a 1/2" 7075 shaft. Can you explain in a bit more detail the application this was in under failure?
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 25-03-2011, 16:58
Andrew Y.'s Avatar
FunYun
AKA: Andrew Yun
FRC #2415
never seen dosent mean never exists.
most common types of 7075 is 0, T6, and T631. Although there are MANY different types such as T7362 is also a common one.
Unread 25-03-2011, 17:07
rahilm's Avatar
AKA: Rahil Mehta
T7351 Actually.
It was on our arm. Basically we have 2 Banebot's gearboxes with chain running up to the arm. We have approx. 50 lb-ft of torque (don't worry, 1:4 chain reduction, only 6.25 lb-ft on each gearbox). We have chain on either side of the arm, and we decided to change the tensioning method to turnbuckles. Almost immediately as we raised the arm, the turnbuckle one side (the twisted side failed) while the other one held. The torque of the arm in addition to tension being held by the chain all released in one instant twisting the shaft, as the tension still held on the other side (on which the gearbox's rollpins sheared)
Unread 25-03-2011, 17:24
Andrew Y.'s Avatar
FunYun
AKA: Andrew Yun
FRC #2415
Originally Posted by rahilm View Post
T7351 Actually.
thanks for the assist...my brains all scrambled this morning
Unread 27-03-2011, 17:10
sometimestommy's Avatar
sometimestommy sometimestommy is offline
Schrödinger's Assistant
AKA: Thomas Moll
FRC #1939 (Ku-Nig-Its)
sometimestommy is on a distinguished road
Whew! thought that was a lead screw
Unread 28-03-2011, 04:57
ligiahag7902 ligiahag7902 is offline
Junior Member
ligiahag7902 is an unknown quantity at this point
I also think so.
