Go to Post The only way to make a noticeable shift in OUR culture is if there are a lot of small shifts. - JVN [more]
Unread 25-03-2011, 17:07
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: pic: Twisted Hex Shaft
Originally Posted by Andrew Y. View Post
gotcha 7075 was the number iw as looking for. Just to be nosey it wasnt 7075 -0 right?
T7351 Actually.
Originally Posted by Brandon Holley View Post
Wow, that is quite a failure for a 1/2" 7075 shaft. Can you explain in a bit more detail the application this was in under failure?
It was on our arm. Basically we have 2 Banebot's gearboxes with chain running up to the arm. We have approx. 50 lb-ft of torque (don't worry, 1:4 chain reduction, only 6.25 lb-ft on each gearbox). We have chain on either side of the arm, and we decided to change the tensioning method to turnbuckles. Almost immediately as we raised the arm, the turnbuckle one side (the twisted side failed) while the other one held. The torque of the arm in addition to tension being held by the chain all released in one instant twisting the shaft, as the tension still held on the other side (on which the gearbox's rollpins sheared)
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 25-03-2011, 17:24
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
Originally Posted by rahilm View Post
T7351 Actually.
thanks for the assist...my brains all scrambled this morning
Unread 27-03-2011, 17:10
sometimestommy's Avatar
sometimestommy sometimestommy is offline
Schrödinger's Assistant
AKA: Thomas Moll
FRC #1939 (Ku-Nig-Its)
sometimestommy is on a distinguished road
Whew! thought that was a lead screw
Unread 28-03-2011, 04:57
ligiahag7902 ligiahag7902 is offline
Junior Member
ligiahag7902 is an unknown quantity at this point
I also think so.
