Go to Post Pompous boasts dont get you anywhere. Results get your name on the book... - Jeremy_Mc [more]
Unread 23-03-2011, 18:15
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
Custom Buttons for drivers?
How would one go about making custom push buttons for the driver? We are making buttons for set positions for our arm and we need to make 9 buttons that we can read in labview. I know its been done but i cant find anything on it. Help?
Unread 23-03-2011, 23:15
Zholl Zholl is offline
AKA: Chris Sherwood
FRC #2996 (Cougars Gone Wired)
Zholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to behold
Re: Custom Buttons for drivers?
You'll most likely want to look at using the Cypress board. It has a number of digital inputs that would be perfect for what you're doing here. I'm not so sure on how to program it, as I'm not a coder myself, but I can tell you it's really easy to wire and set up with the driver station, and our programmer has told me that the programming for it is quite simple. If I recall it should have a disc with it that should help with coding for it. I also seem to remember being told that the driver station sees the digital inputs by default anyway, and I think he was simply programming in Labview for the inputs the computer was recognizing as coming from the board
Unread 23-03-2011, 23:37
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
Programming the Cypress IO module is even easier than that. Don't use the disk it came with, follow the instructions here.
I was looking how to set this up for my team recently, so if you need any help programming or wiring it, feel free to ask me and I'll try to help anyway I can
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 24-03-2011, 01:46
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
We (1708) were looking for an easy solution to the same problem to implement during this week's DC regional. Here's what we came up with:
A USB num pad (example)
This software that allows mapping of keystrokes to a virtual joystick device.
Convenient 3x3 button pattern (with additional buttons for controlling grippers, etc). No wiring required. Optionally, add colored electrical tape and marker annotations to make it pretty.
--Ryan
FRC 766, 2015-, Mentor
Unread 24-03-2011, 15:23
DjMaddius's Avatar
AKA: Matt Smith
--Ryan
Using the numpad was suggested by one of my team mates, just didnt want to deal with keypress events and didnt know how to in labview. I know how to do it all in C languages where i do C# for a living.
Unread 24-03-2011, 15:46
Tommy F.'s Avatar
Tommy F. Tommy F. is offline
Yeah! Collages!
AKA: 7h0m45
FRC #1985 (Robohawks)
Tommy F. is just really niceTommy F. is just really niceTommy F. is just really niceTommy F. is just really nice
Team 1985 took apart a USB Logitech controller and wired buttons to the small board the controller is made with and made a control panel with those. The driver station just reads it as the controller.
FTC 289, 290 & 291 :: FRC 1985
2013 St. Louis Regional Semi-Finalist (with 3411 and 4330), Industrial Design Award
2013 Queen City Regional Winner (with 379 and 447)
Unread 25-03-2011, 09:48
clayman's Avatar
clayman clayman is offline
AKA: Clayton
FRC #3175 (Knight Vision)
clayman is an unknown quantity at this point
If you really want to look boss, get some real arcade buttons: http://www.happcontrols.com/pushbuttons/pushbuttons.htm You could just wire them up to the terminals of a cheapo usb gamepad (ebay).
Unread 25-03-2011, 21:58
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
The fastest way to do this without buying any extra stuff is to take your switches, wire one pole to ground and the other to a signal pin on the Cypress (I'd definitely suggest the andymark/estop robotics cypress carrier/enclosure!) Then just use the "get compatibility IO digital inputs" function in labview and out come your buttons. Keep in mind they may be reversed (TRUE meaning not pressed).
