Go to Post FIRST robots are not six week projects. They are never ending projects where the requirements are changed on an annual basis. - ChrisH [more]
Unread 26-03-2011, 03:15
Alice141 Alice141 is offline
Junior Member
FRC #0004
Alice141 is an unknown quantity at this point
Re: Minibot resistor
1) If you make your resistor out of Tetrix parts or a clever assembly of aluminum and polycarbonate you could claim it's legal. This seems impossible to me, but you may be more inventive. Read <R92> very carefully.
2) In the Introduction, the definition of MINIBOT RACE is "a competition in which MINIBOTS are DEPLOYED, climb the TOWER, and TRIGGER the TARGET. The MINIBOT RACE begins at the start of the END GAME." After the race is over you seem to be able to do whatever you want. If you reverse and gracefully return to the ground, it will be much easier for the students to retrieve your MINIBOT. It's 50/50 but I think the pole mounted chainsaw they showed at the kickoff for removing minibots after a match was a joke.
3) In the introduction, TARGET is defined as "part of the TOWER, attached to the top of the POST. The TARGET is the “finish line” that indicates the MINIBOT has reached the top of the POST." The drawings show it as a disk with two micro-switches that detect the MINIBOT. Lot's has been said on Chiefdelphi about the force required to trip the switches.
