Go to Post I remember seeing that hair do. It is what inspired me to become an MC one day. - Tetraman [more]
Unread 26-03-2011, 09:26
WarehouseCrew WarehouseCrew is offline
FRC #3299 (Warehouse Crew)
Team Role: Parent
WarehouseCrew is an unknown quantity at this point
Wire preference - stranded or solid
What are the pros and cons of using stranded versus solid core wire for the electrical components? I'm not an electrical guy, but am trying to help our student's clean up the rats nest of wiring on our practice robot (may make same changes on competition robot when at the Regional).
We have been using stranded wire, but I just read that solid core wire allows you to make 90 degree bends.
Does your recommendation change based upon the wire size (eg. 12 AWG vs 14 AWG or 18 AWG)?
I'm assuming if we have a motor mounted on an arm that moves (wire needs to have some flexibility) that stranded is preferred. Is that a correct assumption?
Any issues with crimping on ends (eg. eyelet for attaching to Jaguars)?
Thanks.
Unread 26-03-2011, 10:06
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Wire preference - stranded or solid
I would recommend that only stranded wire be used on a robot. If a solid wire breaks, you lose all continuity.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 26-03-2011, 10:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I cannot think of a single instance in an FRC robot where solid wire would be preferred, unless it was wire-wrap-wire on a hand-built prototype sensor circuit or something of the sort.
Unread 26-03-2011, 10:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Solid wire is commonly used in houses. Houses don't usually move, so it works fine. But robots move, and the flexing and vibration could lead to the wire breaking eventually.
Unread 26-03-2011, 10:45
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
I would highly recommend sticking with stranded.
A parent kindly donated some solid stranded wire left over from a housing project last year. It is very difficult to work with, especially if you are at the stage during which you are moving electronics around.
Our crimps (unsoldered) didn't stay on very well either.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 26-03-2011, 11:53
kstl99's Avatar
kstl99 kstl99 is offline
AKA: Kevin
FRC #1922 (Oz-Ram)
kstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond repute
Send a message via AIM to kstl99
I am glad to see that all are agreeing with stranded. Solid can break with vibration, metal fatigue I believe it is called. Also, screw and crimp terminations work much better with stranded, which is why you should not tin wires before crimping or using in a screw terminal.
Lastly, 90 degree bends with wire are a bad thing. They can cause the wire to crack inside. Most wire has a minimum bend radius as part of its specs. Better to loop into a connection if possible, avoiding stress on the connection.
Unread 26-03-2011, 12:29
nuttle nuttle is offline
AKA: Allen Nuttle
FRC #4080
nuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud of
The only thing to watch out for with standed is that is you cut short amounts from the ends, you create a bunch of short, fine individual wires that are as bad as metal shavings in terms of getting into electronics and causing shorts. Also, it is fairly easy to have individual strands break and cause the same problem. It is good practice to 'tin' the ends of stranded wire before you trim the ends and insert them into things like the power distribution board or a Wago connector. You should also twist the ends, but it is still a good idea to tin them. This should prevent these problems. We also solder crimp connectors, splices, etc. The increased reliability is worth the little bit of extra time and tiny amount of added weight.
Stranded wire comes with various stand counts, even for the same wire gauge. Finer strands are more flexible, but tend to make the above problems worse.
Unread 26-03-2011, 14:20
DonRotolo's Avatar
Back to humble
FRC #0832
But to reiterate: Solid wire has no place on an FRC robot.
Unread 26-03-2011, 17:58
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
BitTwiddler is on a distinguished road
Tinning of the wires to be inserted into Wago connectors is NOT recommended by Wago. The Wago's are designed to make a solid connection by actually compressing the strands in a predictable and reliable manner. Tinning the wires would prevent them from compressing properly thus reducing the contact area. There has been a discussion on this topic at
http://www.chiefdelphi.com/forums/sh...ad.php?t=69355
Unread 26-03-2011, 19:48
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Wire preference - stranded or solid
Stranded wire comes in a variety of different # of strands (more strands = higher cost) for the same gauge wire. The greater the number of strands, the more flexible the wire. In addition, the insulation type will also affect wire flexibility. Use crimp connectors on ends that are placed on screw terminals. Aways twist the strands together, use proper wire strippers to avoid cutting any of the strands, and test your crimp connection by pulling on the wire/crimp connection to ensure a soild connection. If you can't get a small enough connector for the smaller gauges of wire, strip more insulation and double or triple back the bare wire into the connector before crimping.
Solid wire is highly prone to breaking where you strip the insulation, as it can be easily nicked, which will lead to failure if you don't use a wire stripper. Use small zip ties and Velcro wire ties to bundle your wiring paths as much as possible.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 26-03-2011, 21:20
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
My team placed the bundlles of wires for our claw's roller motors inside of cables resembling curly telephone cables. Worked pretty well.
Unread 27-03-2011, 02:46
bookworm0422's Avatar
bookworm0422 bookworm0422 is offline
bookworm0422
AKA: Karl Heinrich
FRC #0313 (Bionic Zebras)
bookworm0422 is an unknown quantity at this point
Also let us not overlook that the Game Manual does not allow us to use solid core wire any where on our robots no matter the use for it.
Unread 27-03-2011, 06:11
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
What rule is that?
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 27-03-2011, 06:28
Hodge1
There is no rule I can find governing use of solid wire. The rules cover gauge and color coding. As the say in Missourie, "Show Me". In the end, stranded is the preferred wire of choice.
Sweat the details
Unread 27-03-2011, 07:08
Let's start out with the first post. Either stranded wire or solid wire can be used on the robot. Either can be bent at 90 degrees, solid will hold that bend better than stranded. The Wago terminations are better suited for stranded, untinned wire insertion of one wire only. As the wire is inserted and the terminal is allowed to compress it, more surface area is created between the wire and the terminal giving a lower contact resistance. Tinned, stranded wire often reduces contact surface area to a fraction of either wire terminations raising the contact resistance and therefore heating the contact. Although the PD can accept solid wire termination, stranded is better in my opinion. Solid wire on moving and vibrating objects is asking for wire failure due to flexing of a single conductor. Stranded wire handles vibration with far less metal fatigue.
