Go to Post I don't care if my team wins. I care if they try their hardest to win. - pfreivald [more]
Unread 26-03-2011, 17:58
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Re: Wire preference - stranded or solid
Originally Posted by nuttle View Post
. It is good practice to 'tin' the ends of stranded wire before you trim the ends and insert them into things like the power distribution board or a Wago connector.
Tinning of the wires to be inserted into Wago connectors is NOT recommended by Wago. The Wago's are designed to make a solid connection by actually compressing the strands in a predictable and reliable manner. Tinning the wires would prevent them from compressing properly thus reducing the contact area. There has been a discussion on this topic at
http://www.chiefdelphi.com/forums/sh...ad.php?t=69355
Unread 26-03-2011, 19:48
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Wire preference - stranded or solid
Stranded wire comes in a variety of different # of strands (more strands = higher cost) for the same gauge wire. The greater the number of strands, the more flexible the wire. In addition, the insulation type will also affect wire flexibility. Use crimp connectors on ends that are placed on screw terminals. Aways twist the strands together, use proper wire strippers to avoid cutting any of the strands, and test your crimp connection by pulling on the wire/crimp connection to ensure a soild connection. If you can't get a small enough connector for the smaller gauges of wire, strip more insulation and double or triple back the bare wire into the connector before crimping.
Solid wire is highly prone to breaking where you strip the insulation, as it can be easily nicked, which will lead to failure if you don't use a wire stripper. Use small zip ties and Velcro wire ties to bundle your wiring paths as much as possible.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 26-03-2011, 21:20
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
My team placed the bundlles of wires for our claw's roller motors inside of cables resembling curly telephone cables. Worked pretty well.
Unread 27-03-2011, 02:46
bookworm0422's Avatar
bookworm0422 bookworm0422 is offline
bookworm0422
AKA: Karl Heinrich
FRC #0313 (Bionic Zebras)
bookworm0422 is an unknown quantity at this point
Also let us not overlook that the Game Manual does not allow us to use solid core wire any where on our robots no matter the use for it.
Unread 27-03-2011, 06:11
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
What rule is that?
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 27-03-2011, 06:28
Hodge1
There is no rule I can find governing use of solid wire. The rules cover gauge and color coding. As the say in Missourie, "Show Me". In the end, stranded is the preferred wire of choice.
Sweat the details
Unread 27-03-2011, 07:08
Let's start out with the first post. Either stranded wire or solid wire can be used on the robot. Either can be bent at 90 degrees, solid will hold that bend better than stranded. The Wago terminations are better suited for stranded, untinned wire insertion of one wire only. As the wire is inserted and the terminal is allowed to compress it, more surface area is created between the wire and the terminal giving a lower contact resistance. Tinned, stranded wire often reduces contact surface area to a fraction of either wire terminations raising the contact resistance and therefore heating the contact. Although the PD can accept solid wire termination, stranded is better in my opinion. Solid wire on moving and vibrating objects is asking for wire failure due to flexing of a single conductor. Stranded wire handles vibration with far less metal fatigue.
Unread 27-03-2011, 14:11
Hodge1
Al,
Excellent point made on stranded wire compression at a terminal connection.
Sweat the details
Unread 27-03-2011, 18:36
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
There is no reason to use solid core for any of the "large wires" i.e. 22 AWG or larger, but it's fairly common to see some of the bundled data wires (RJ12 telephone cable for CAN bus or ethernet cabling) using solid core rather than stranded. I'd still prefer to use stranded for these applications but IMHO it's less critical.
Unread 27-03-2011, 20:25
MagiChau's Avatar
AKA: Michael Chau
If my memory serves me correctly the required power convertor for 12V to 5V solely for the bridge's power supply has solid wires for connecting it to the power supply & bridge.
Unread 28-03-2011, 04:54
Chau,
Those are pre-tinned stranded wire. You insert one side in the connector for the PD and solder the output to the power cable for the radio. Pre-tinned seems to indicate the primary or intended customer for this regulator would solder it to a circuit board.
Unread 28-03-2011, 10:25
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FYI - When electricity flows through a wire, it mostly flows on the surface of the wire, not through the middle. This effect is more pronounced on high frequency AC than it is on DC or low frequency AC. This means that a "wire" of a given size that made up of many smaller strands can carry more power than a solid wire - simply because the stranded wire has more surface area. Plus flexibilty is key on our robots and all the termination mechanisms we are given work best on stranded wire.
So... my professional opinion is there are no compelling reasons to use solid-core wire on a FRC robot (even if it was donated).
HTH
