Re: Wire preference - stranded or solid
My team placed the bundlles of wires for our claw's roller motors inside of cables resembling curly telephone cables. Worked pretty well.
Also let us not overlook that the Game Manual does not allow us to use solid core wire any where on our robots no matter the use for it.
What rule is that?
There is no rule I can find governing use of solid wire. The rules cover gauge and color coding. As the say in Missourie, "Show Me". In the end, stranded is the preferred wire of choice.
Let's start out with the first post. Either stranded wire or solid wire can be used on the robot. Either can be bent at 90 degrees, solid will hold that bend better than stranded. The Wago terminations are better suited for stranded, untinned wire insertion of one wire only. As the wire is inserted and the terminal is allowed to compress it, more surface area is created between the wire and the terminal giving a lower contact resistance. Tinned, stranded wire often reduces contact surface area to a fraction of either wire terminations raising the contact resistance and therefore heating the contact. Although the PD can accept solid wire termination, stranded is better in my opinion. Solid wire on moving and vibrating objects is asking for wire failure due to flexing of a single conductor. Stranded wire handles vibration with far less metal fatigue.
Al,
Excellent point made on stranded wire compression at a terminal connection. ![]() |
#7
There is no reason to use solid core for any of the "large wires" i.e. 22 AWG or larger, but it's fairly common to see some of the bundled data wires (RJ12 telephone cable for CAN bus or ethernet cabling) using solid core rather than stranded. I'd still prefer to use stranded for these applications but IMHO it's less critical.
#8
If my memory serves me correctly the required power convertor for 12V to 5V solely for the bridge's power supply has solid wires for connecting it to the power supply & bridge.
#9
Chau,
Those are pre-tinned stranded wire. You insert one side in the connector for the PD and solder the output to the power cable for the radio. Pre-tinned seems to indicate the primary or intended customer for this regulator would solder it to a circuit board. |
#10
FYI - When electricity flows through a wire, it mostly flows on the surface of the wire, not through the middle. This effect is more pronounced on high frequency AC than it is on DC or low frequency AC. This means that a "wire" of a given size that made up of many smaller strands can carry more power than a solid wire - simply because the stranded wire has more surface area. Plus flexibilty is key on our robots and all the termination mechanisms we are given work best on stranded wire.
So... my professional opinion is there are no compelling reasons to use solid-core wire on a FRC robot (even if it was donated). HTH |
#11
Not exactly, the "skin effect" is more pronounced by higher voltages and higher frequencies. While the Jaguars may introduce this effect, I am guessing it is very small compared to the other losses in the system. There is very little effect at DC.
#12
Also keep in mind that there are different kinds of stranded wire. The number of strands and the insulation material can bake it hold a bend more or less easily. On our robot this year, we've got two different types of power wire. One is very stiff, and holds a bend very nicely. We use that for a vast majority of our wiring, so we can get nice, clean runs that aren't going to flop loose over time. The second type is much, much more flexible. It won't hold a bend at all. We use that for our elevator, since we require that wire to be constantly moving. Stiffer wire in this situation would be more prone to breaking over time.
#13
HTH |
