Go to Post "git er done" but do it right. - CJO [more]
Unread 26-03-2011, 22:36
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
The Hardest Drive System To Program:
What is the hardest drive system to program?
Unread 26-03-2011, 22:39
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: The Hardest Drive System To Program:
Any base drive system is not incredibly difficult to program. Programming an effective control system for a drive system is hard.
see:
  • Failure checking (state machine, redundancies)
  • Human error correction
  • Mechanical error correction
I really don't know what to answer your question with, everytime I think of a drive system I think of all the ways I could improve it with pieces of code - would be very difficult to pick a single one, and would require more context.
Unread 26-03-2011, 22:41
mobilegamer999 mobilegamer999 is offline
FRC #3357 (Comets)
mobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the rough
My opinion would be swerve drive.
Theres pre-made code in WPILIB already for Tank, Arcade, Mechanum and one other I believe. But swerve is the only one out there that requires pretty much completely custom code to get working.
Unread 26-03-2011, 22:43
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Can you explain swerve drive? Apparently, my understanding of the said swerve drive is actually "crab drive". Tell me WHAT it is, not how or anything like that.
Unread 26-03-2011, 22:46
Emily Horsman
To be fair, your original post was only
Crab drive is a specific type of swerve drive, where there are four rotating modules.
Unread 26-03-2011, 22:49
Emily Horsman
I would recommend reading this excellent white paper by Ian Mackenzie
http://www.firstroboticscanada.org/s...irectional.pdf
Unread 26-03-2011, 22:50
FRC #3357 (Comets)
Each wheel module rotates along its vertical axis as well as rotating along the wheels axle (for movement which is usually helpful), so to go at a 45 degree angle, you rotate all wheels to 45 deg and then just drive all wheels straight.
Unread 26-03-2011, 22:54
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
see:
Can you elaborate on your 3 points a bit more please?
Unread 26-03-2011, 22:55
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
In my opinion how you want to implement the drive will make the programming difficult. For example a competent programmer can program a swerve that can move the wheels forward and rotate them directly with a joystick but making a program that takes into account the position of the wheels relative to the closest direction to rotate and stops the wheels from moving till they reach the correct angle while taking into account the angle of the robot and the desired direction will make the programming more difficult. i have found the most fun is had trying to make an extremely complex drive train simple to use! Now with just the simple setup (aka. nothing unique) i would agree it would be the swerve because of the availability of prewritten code and for the difficulty in making the drive simple to use.
~Jon
Expect the best, Prepare for the worst
Unread 26-03-2011, 23:00
Emily Horsman
If a sensor relating to your drive system fails, what is going to happen to your robot? A lot of teams run a separate task on the cRio that monitors for failures and then triggers a state change when a failure occurs. For instance let's say a gyro stops reading values, rather than making the robot spin in circles, the drive system would ignore gyro values.
Redundancies being increased reliability of a drive system, http://en.wikipedia.org/wiki/Redundancy_(engineering)
How much money would you put on the fact that your driver can hold two joysticks at 50% throttle precisely? Probably not a lot.
Motors aren't made equal. Two motors of the same model will rarely go at the same speed. Using encoders and other techniques to correct this.
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Now, keep in mind, I have not used any prewritten code except for theses classes: PWM and Joystick.
Unread 26-03-2011, 23:01
Emily Horsman
Precisely.
Unread 26-03-2011, 23:03
connor.worley's Avatar
connor.worley connor.worley is online now
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
They're all fairly simple until you get to a full swerve drive. But even then it's just some control loops and a bit of trigonometry.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 26-03-2011, 23:04
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
"Safe Mode": If triggers, switches to bare bone drive code.
Multiple sensors to "check" each other
We just used dead zones for the human error part
We didn't use the encoders because there was too much noise that I did not trust them enough to use it.
Unread 26-03-2011, 23:08
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Joystick has a X and a Y axis; get the inverse tangent of the Y/X. You have your angle (of course, there is something to check if the x and y are both negatives and or on the axis it self. That is easy) Rotate the wheels to that angle (Closed Loop System) Then the magnitude (Pythagorean theorem) is the speed to the motors.
How ever, I heard that it is the crab drive.
