Go to Post If it wasn't for 47, none of us would be here. - Taylor [more]
Unread 26-03-2011, 22:54
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: The Hardest Drive System To Program:
Originally Posted by basicxman View Post
Any base drive system is not incredibly difficult to program. Programming an effective control system for a drive system is hard.
see:
  • Failure checking (state machine, redundancies)
  • Human error correction
  • Mechanical error correction
I really don't know what to answer your question with, everytime I think of a drive system I think of all the ways I could improve it with pieces of code - would be very difficult to pick a single one, and would require more context.
Can you elaborate on your 3 points a bit more please?
Unread 26-03-2011, 23:00
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
If a sensor relating to your drive system fails, what is going to happen to your robot? A lot of teams run a separate task on the cRio that monitors for failures and then triggers a state change when a failure occurs. For instance let's say a gyro stops reading values, rather than making the robot spin in circles, the drive system would ignore gyro values.
Redundancies being increased reliability of a drive system, http://en.wikipedia.org/wiki/Redundancy_(engineering)
How much money would you put on the fact that your driver can hold two joysticks at 50% throttle precisely? Probably not a lot.
Motors aren't made equal. Two motors of the same model will rarely go at the same speed. Using encoders and other techniques to correct this.
Unread 26-03-2011, 23:04
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
"Safe Mode": If triggers, switches to bare bone drive code.
Multiple sensors to "check" each other
We just used dead zones for the human error part
We didn't use the encoders because there was too much noise that I did not trust them enough to use it.
