Go to Post The world is run by those who show up. - AdamHeard [more]
Unread 26-03-2011, 23:00
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: The Hardest Drive System To Program:
Originally Posted by davidthefat View Post
Can you elaborate on your 3 points a bit more please?
> Failure checking (state machine, redundancies)
If a sensor relating to your drive system fails, what is going to happen to your robot? A lot of teams run a separate task on the cRio that monitors for failures and then triggers a state change when a failure occurs. For instance let's say a gyro stops reading values, rather than making the robot spin in circles, the drive system would ignore gyro values.
Redundancies being increased reliability of a drive system, http://en.wikipedia.org/wiki/Redundancy_(engineering)
> Human error correction
How much money would you put on the fact that your driver can hold two joysticks at 50% throttle precisely? Probably not a lot.
> Mechanical error correction
Motors aren't made equal. Two motors of the same model will rarely go at the same speed. Using encoders and other techniques to correct this.
Unread 26-03-2011, 23:04
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
"Safe Mode": If triggers, switches to bare bone drive code.
Multiple sensors to "check" each other
We just used dead zones for the human error part
We didn't use the encoders because there was too much noise that I did not trust them enough to use it.
