Go to Post Many students I have met will insist that nothing is better than FIRST robotics. And most people would agree that a ham sandwich is better than nothing. So does it logically follow that a ham sandwich is better than FIRST robotics? - tsaksa [more]
Unread 23-03-2011, 20:29
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
Re: pic: Lamp_Switch
Our team's minibot used a similar switch. We passed inspection at the NYC Regional. We brought the packaging that said something like "Toggling lamp light switch" just in case, but we didn't have any issues with the inspectors.
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
Unread 23-03-2011, 22:30
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Originally Posted by MrHance View Post
Past observations living in many apartments and house over the last 40 years or so.
That would probably have changed my interpretation Team update 12 does indeed allow these switches. Sorry for the confusion - it was my first time inspecting and I haven't had much time with FRC this year. I'll make sure to read the rules three times next year
Unread 23-03-2011, 23:50
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
Team 2057 used this exact switch.. its with the "special switches" at home depot. It was successful for our minibot but BE CAREFUL.. it does take a lotta force to push it in.
Best of luck
2057
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 24-03-2011, 01:05
El Geffe's Avatar
El Geffe El Geffe is offline
Mars here I come
AKA: Geoff
FRC #0060 (Bionic Bulldogs)
Team Role: Driver
El Geffe is an unknown quantity at this point
I glad this is deemed acceptable, because as TheOtherGuy said we did have some difficulty proving that several parts of our minibot were legal, including this exact light switch and some non-slip pad we usually use as tire tread.
Really? We didn't have any trouble pushing it in. In fact' we hit the top so hard once it bust the switch right out of the plastic casing.
2011 - AZ Regional Finalists with 2449 and 1165
2011 - Vegas Champions with 2984 and 987
2011 - Championships ?
Unread 24-03-2011, 12:10
clayman's Avatar
clayman clayman is offline
AKA: Clayton
FRC #3175 (Knight Vision)
clayman is an unknown quantity at this point
Instead of using a switch, we just used 5A fuses on the minibot - it's a bit of a pain to switch them each time (they blow as soon as the motors try to drive through the top of the pole), but we don't have to deal with any... switch
Unread 24-03-2011, 13:03
Unregistered User
AKA: Kevin Forbes
How long would it take for a 5 amp auto-reset fuse to reset? I wonder if that's a possible solution to ensuring the tower is triggered...
EDIT: then again, it needs to be an equivalent type fuse to the Tetrix one. Oh well...
Unread 24-03-2011, 22:17
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: pic: Lamp_Switch
good find, and good post. will certainly help some teams. Any idea how much force is needed to push the switch on/off?
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 25-03-2011, 19:17
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I can't speak for the team truthfully, but 88 appeared to be using that exact switch on their minibot in Baltimore.
If you are a direct drive under 5 pounds, you should be dandy.
Unread 25-03-2011, 23:18
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Wow! What a great idea! Way to think out of the box!
Steve
Unread 25-03-2011, 23:55
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
In Seattle and Portland similar switches were/are on many minibots. That passed inspection w/o issues.
There was a team that had a universal headlight switch (along with some resistors) but we got that changed before inspection.
Unread 26-03-2011, 23:01
PingPongPerson's Avatar
PingPongPerson PingPongPerson is offline
Hardcore Robot Addict
AKA: Michael Groom
FRC #0955 (CV Robotics)
PingPongPerson will become famous soon enough
We argued for about an hour or two with inspectors about what the definition of "common household lightswitch" is, and it appears that as long as the switch is sold as a light switch, and can handle 125V at 6A, it is ok.
Team 955
Raiderbot
Unread 27-03-2011, 18:17
waitwhat?'s Avatar
waitwhat? waitwhat? is offline
Driver Coach
AKA: Bunca
FRC #0747 (Flight Crew)
waitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant future
This is the switch we use. There can be no way of not passing this switch during inspection. The switch actually has "limit switch" written right onto it. It works perfectly. A little pricey but gets the job done. This switch, once engaged, requires you manually reset it. Hence the name "manual reset safety limit switch". Here is the McMaster part number 7336K51
http://images2.mcmaster.com/Contents...ng?ver=1180392
Unread 28-03-2011, 04:59
Michael,
The current and voltage rating is not included in the rules. Simply the switch must be marketed or labeled as a "light switch" to pass inspection.
Wait,
That is an expensive limit switch but a limit none the less. It should pass inspection.
Unread 28-03-2011, 19:25
waitwhat?'s Avatar
Driver Coach
AKA: Bunca
Michael,
Wait,
Very expensive limit switch, but works like a charm. Wish I had a good video of it in action with the minibot.
Unread 28-03-2011, 20:04
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
While I appreciate this discussion, the answer really is 'it depends'. We were in Portland this past weekend and the definition was "household wall light switch". And before I get a lot of flames, I did very heavily argue that the GDC ruled that the 'wall' portion was not necessary and that lamp switches were valid. I was in heated discussions with 5 different inspectors including the head inspector, and they said that "they were told be New Hampshire to only accept wall light switches or Tetrix switches", the limit switches were acceptable however.
We had to scramble to change out our 'lamp' switch and replace it with a Tetrix switch to pass inspection.
Like I said ... It depends on who, what, and where you talk.
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
