Go to Post FIRST, in itself, will not make you an engineer. - RogerR [more]
Unread 27-03-2011, 06:54
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Tetrix Switch not allowed?
Originally Posted by Chexposito View Post
you were completely legal from what i can tell on the switches.
how anyone came under the impression a tetrix switch is not allowed is beyond me.
Because it is "hidden" within. R92, stating that Tetrix NXT components are allowed. All sensors on that list are allowed, which included your switch.
However, the inspector, IMHO, was correct in saying your "lamp switch" is not marketed as a light switch. Do some research and shop around for one that is marketed as a light switch that will suit your application. As an alternative, there are limit snap switches that are not momentary and exceed your contact amp requirements. Push once, it's on, push again, it's off. digging for what you need is part of the game.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
