Re: Help the field crew, reset your gyro in autonomous
) to something that activates the LED? |
As it turns out, since the gyro open is blocking, I shouldn't need to do anything. The default code flashes USER 1 LED in PeriodicTasks.vi. PeriodicTasks.vi won't run until Begin.vi completes. So... as long as open gyro is done in Begin.vi (which is where it should be), USER 1 LED will not start flashing until the gyro cal is complete. Yea for simplicity. |
I just had a thought that I figured I would throw out there.
What about using a Driver Station input to trigger the Gyro Open in Autonomous Disabled? Then the gyro bias can be calculated during team introductions. |
This is an important issue as more teams are using the gyro.
We are thinking of adding a relatively quiet but noticeable buzzer that will turn on for 8 seconds- the last 2 seconds we will use to initialize the gyro. If the field crew is moving the robot when the buzzer sounds, they know they have a few seconds to stop moving the bot- if they don't, they at least know that they should reset the cRIO. |
