Go to Post Students can learn to drive on whatever they give us. Ramps, carpet, grating, HDPE, lexan, diamond plate, regolith, other robots the driver station wall, referees, stairs, Dean, the bar, goals, the scorer's table, you name it, I've watched robots somehow manage to drive on it - Peter Matteson [more]
Unread 27-03-2011, 16:20
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Top Ten Reasons Robot Loses Com in a collision ?
Check for ground shorted to the robot frame. The cRIO and camera are both chassis grounded and must be isolated from the robot frame. Also, if you are using any of the RS-775 motors make sure they don't have a lead shorted to the case.
