Go to Post I guess true innovation is when you can actually harness physics to do what you want. Heck -- that sounds suspiciously like engineering. - JVN [more]
  #46   Spotlight this post!
Unread 07-02-2011, 18:22
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: pic: burnt up TETRIX motor
We had the same problem, a burned out motor. I assume that it is a blown inductor. How many amps will blow out the inductor? And is there an acceptable fuse that will prevent this from happening, preferably one that fits in the battery's fuse clip?
Thanks,
David
  #47   Spotlight this post!
Unread 13-03-2011, 18:02
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
repairing burnt up TETRIX motor
In order to resore our blown Tetrix motor for "development" use (working on them is an "illegal" mod), I took it apart as follows:
- remove from gearcase
- mark the orientation of the brush plate relative to the case
-file away the areas where the case is "lipped over" to hold the brush plate. I used a small triangular file.
- carefully tap the opposite end (the gear) on a hard surface to pop the brush plate up.
- do not pull up on the brush plate! This will damage the brushes. Instead, slide it sideways off the commutator.
Once I had it apart, I could see that the inductor was obviously smoked. I unsoldered it, and in its place, soldered a solid wire (don't worry, it will still work!)
To reassemble:
- create 2 loops using fine thread. Hook one loop around each of the brushes.
- with the loops, carefully pull the brushes far enough apart to clear the commutator.
- pinch the threads around the circumference in a way that will hold the brushes while you reinstall the brush plate on the shaft.
- when it's in place, snip each thread loop and pull one end to remove them.
- place the motor on its side and using a small hammer, gently "tab over" the housing adjacent to the notches you filed away to remove the brush plate.
If you are as lucky as me, the motor will run like new! Granted, it doesn't have the "inductor", but it seems to work just fine for testing and development. It pains me to have to spend $30 each time a motor blows!
  #48   Spotlight this post!
Unread 27-03-2011, 17:01
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
What current should the inductor be rated for?
I see its legal to repair it as per <R93>
b) a burned out motor may be repaired by replacement of the burned-out inductor with an identical part
Brian K
Team 1225 Robotics Mentor
  #49   Spotlight this post!
Unread 27-03-2011, 17:44
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
I believe that the very has been stated somewhere but no one can find a replacement part
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
  #50   Spotlight this post!
Unread 28-03-2011, 04:56
Al Skierkiewicz Al Skierkiewicz is online now
Brian,
The highest current device I have found thus far for this size package is 900ma. Unfortunately, those are non-stock at Mouser.
  #51   Spotlight this post!
Unread 28-03-2011, 09:14
SuperBK's Avatar
AKA: BrianK
Thanks Al, what size package is it? (length, width)? Ours is locked away in our trailer since we got home Saturday night from Palmetto. We have a week and a half to get ready for our next regional.
Brian K
  #52   Spotlight this post!
Unread 25-04-2011, 15:17
lonski lonski is offline
FRC #2486
lonski is an unknown quantity at this point
Originally Posted by vincentkee View Post
Does anyone have problems with the tabs of the motors frequently breaking off?
We have our minibot climb up a steel pole that doesn't have a top so it falls down. We don't always catch it and then the tabs of the motors keep breaking, rendering them useless unless we solder on replacements.
we have had troubles with the connectors and we soldered the wires to the connector and never had any more issues with them beraking. we just have an issue with a brand new motor that we bought just burnt out. we broke in the motor before we put preassure on the motor and then we climed the pole and the tird time and the motor just randomly stoped. the shaft spins nicely the motor didnt heat up or smoke. anyone know how to open the motor
  #53   Spotlight this post!
Unread 25-04-2011, 15:39
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Easiest way is to lightly tap on the end of the motor shaft without the back end of the motor supported. The back piece pops right off.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
  #54   Spotlight this post!
Unread 26-04-2011, 08:48
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Originally Posted by colin340 View Post
my electrical people said a fuse would take to long to blow as the resistor or inductor was gone in under 2 sec
15- and 10-amp fuses saved our motors more often than 20's did. Once we had a design that worked, we switched back to 20-amp fuses because we had more of them, but the lower amperage was helpful.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
