Go to Post All I know is I have fun building a robot, and I have fun competing with it. If I get an award, I'm happy. If I don't, then too bad. Either way, I'm coming back next year. - Tom Bottiglieri [more]
Unread 27-03-2011, 21:40
Vincent R Vincent R is offline
FRC #2505 (Electric Sheep)
Vincent R is an unknown quantity at this point
Physics of robot base vs. width
One of the basic techniques to improve 6 wheels arcade drive is to lower the middle wheels to allow the robot to "rock." I understand that this is to effectively reduce the robot base (distance from back wheel to front wheel) and improve turning.
My question is how do you explain this phenomenon using physics? The way I think of it is that force is applied by the wheels producing a torque about (assuming) the centre of all the wheels. But whether if it is 4 wheels or 6 wheels in contact, the perpendicular distance from the force applied by the wheels to the axis of rotation remains the same and the centre of mass stays relatively the same when you are "rocking". So how does this improve turning?
Unread 27-03-2011, 21:46
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Physics of robot base vs. width
The outer wheels have to slide on the carpet during a turn, hence the term "skid steer". By having a drop center wheel set, you reduce the amount of weight on those outer wheels, and thus less friction you have to overcome.
Unread 27-03-2011, 21:54
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The idea behind the rocking 6wd is to shorten the wheelbase while maintaining the same stability as the longer wheelbase.
To turn a "skid steer" system the wheels have to slip. Imagine a robot with 4 wheels on the corners, a level 6wd will behave pretty similar to this system. The force trying to turn the robot is applied at a distance equal to 1/2 the robot width. The friction force preventing the robot from turning is applied at a distance equal to 1/2 the robot width.
If the length is longer than the width, and the wheels have similar coefficients of friction in the two different directions, the torque about the center of rotation being applied by the wheels trying to spin is not enough to overcome the torque being applied by the friction of the wheels being pushed sideways.
Unread 27-03-2011, 21:59
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Chris Hibner wrote a great paper on 4wd turning.
http://www.chiefdelphi.com/media/papers/1443
I would recommend reading through it. Basically, a 6wd drop center is essentially 2 4wds (as others have stated).
An interesting phenomenon can occur with 6wd with a reasonably flexible chassis. Even with stiff rails, if the two sides are not torsionally stiff relative to each other, then diagonal outer wheels can end up touching at the same time. This will cause it to act like a longer wheel base which can reduce maneuverability.
Unread 27-03-2011, 22:03
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
We used this paper too way back to explain why our 4 wheel robot had trouble turning in 2003. I recommend it too.
On a flat surface with drop center 6 wheel drive. Only 4 wheels can touch the ground, 2 have to be the center wheel. So it turns a robot with over 30 inch wheel base, to one that is about 15 inches in length. By reducing the wheel base length, you are reducing the moment around the axis of rotation resulting from wheel friction. You are essentially making a smaller lever arm lowering the force. That is why its easier for wide robots to turn with 4 wheels the long robots running 4 wheels.
On the carpet, because the robot sinks in, the effect merged with description the vikesrock stated above. Really all 6 wheels are touching the carpet, some wheels carry more weight than others. Its the combination of these two effects that make this system work so well in FIRST.
Unread 27-03-2011, 22:49
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
In addition to the decrease in skidding with the dropped center, the reasoning behind this can also be explained with vectors. With only the center wheels and one pair of the side wheels touching in the dropped center design, the robot is turning about the center of those four wheels rather than the center of the robot. This means that if the force of the wheels are broken up into vectors, the rotational component of the turning wheels (portion of the vector perpendicular to the imaginary segment connecting the center of rotation and the wheel) is much larger in the dropped center than it is in the non-dropped center six wheel base. The other component of the force from the wheel is wasted because it is canceled out by a force from the opposite wheel on the bot.
Diagram:
In this diagram, the red arrows are the rotational component of the force provided by the wheels and X marks the center of rotation. In this particular moment, the top 4 wheels on the dropped center bot are contacting the floor and the bottom two are not. Note that the rotational vectors on the dropped center diagram are significantly larger than those on the non-dropped center bot, especially at the corners.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
