Go to Post The only constant in FRC is change. Learning to adapt to change in competition is the best way to prepare for change in real life. - Jessica Boucher [more]
  #46   Spotlight this post!
Unread 27-03-2011, 15:05
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
Re: Solution: Variable position of cylinder in compliance with <R74>
Originally Posted by Roboman01 View Post
Trapped air that is not pressurized beyond atmospheric pressure is legal, to my knowledge. The only thing that is making the arm difficult to move is the vacuum generated inside the cylinder, since the check valves prevent air from entering the system. The extra push buttons let air into the cylinder. Vacuums are not subject to the rules governing pneumatic systems, according to <R66>, part G. Once the vent plug valve is open, any positive pressure created by the movement of the arm is exhausted as it is created, through the check valves, and the only pressure that exists is negative (vacuum).
I think that is a rather liberal way of reading the rule:
<R73> The pressure vent plug valve must be connected to the pneumatic circuit such that, when manually operated, it will vent to the atmosphere to relieve all stored pressure.
and
<R66G>For the purposes of the FRC, a device that creates a vacuum is not considered to be a pneumatic device and are not subject to the pneumatic rules (although they must still satisfy all other appropriate rules). These include, but are not limited to, venturi-type vacuum generators and off-the-shelf vacuum devices (as long as they are powered by provided or permitted motors).
Good luck to you when you play. I just hope you have a "plan B" ready before you pack up for your regional, however.
  #47   Spotlight this post!
Unread 27-03-2011, 15:18
Roboman01 Roboman01 is offline
AKA: Bradley Matheus
FRC #0687 (Nerd Herd)
Roboman01 is an unknown quantity at this point
Actually, we didn't end up using this system at either the San Diego or the Los Angeles regional. We brought the system along with us, as a "Plan C," in case neither of our new gearboxes would lift the arm. Come to think of it, I should have had an inspector look at the system to determine its legality. I'll have to see about doing that at St. Louis.
BE A NERD!
  #48   Spotlight this post!
Unread 27-03-2011, 15:45
Electrical Engineer
Rookie Year: 1995
Yes, vacuum systems are exempt but you are talking about a hybrid pneumatic/vacuum system. Therefore, the system would almost certainly be considered pneumatic by an inspector.
Also, check valves are not legal this year.
JMHO,
Mike
Mike Betts
As easy as 355/113...
  #49   Spotlight this post!
Unread 27-03-2011, 21:50
JMHO,
Mike
Still, it's not generating any positive pressure, which is generally what "pressure" is considered. If I were to hook up gauges, such as the ones from the KOP, to each cylinder supply line, both would read 0 psi, since they only measures on a positive scale. The mere fact that a pneumatic system is a "hybrid" in a certain configuration does not necessarily mean that it is illegal. It would be considered a vacuum-generating device when pressure is released, and a pneumatic device when pressurized. In a week, after my spring break is over, I'll create a video to better demonstrate my point.
Also, since the "check valves" that I'm using are technically flow-control valves, they are legal, as I stated previously.
BE A NERD!
  #50   Spotlight this post!
Unread 27-03-2011, 22:48
Electrical Engineer
Rookie Year: 1995
...Also, since the "check valves" that I'm using are technically flow-control valves, they are legal, as I stated previously.
I know what you have stated and I'm not going to argue with you as it seems that you have made up your mind.
However, for the sake of other readers, the GDC has stated that if a component contains a check valve, it is illegal.
I do not need to like their ruling and I will not defend it... However, if it walks like a duck and sounds like a duck...
JMHO,
Mike
Mike Betts
  #51   Spotlight this post!
Unread 27-03-2011, 22:57
The post you are linking to is from 2010. Also, flow control valves with built-in check valves are included in the KOP.
BE A NERD!
  #52   Spotlight this post!
Unread 27-03-2011, 23:35
Electrical Engineer
Rookie Year: 1995
My apologies on the 2010 link... I hate when I do that...
I don't know of any flow control valves in the KOP this year but I'll not press it...
Good Luck...
Mike Betts
  #53   Spotlight this post!
Unread 28-03-2011, 04:50
Doesn't indicate positive or negative pressure, simply all stored pressure.
  #54   Spotlight this post!
Unread 28-03-2011, 16:25
True, but negative pressure is a vacuum, and vacuums are not subject to the rules.
BE A NERD!
  #55   Spotlight this post!
Unread 28-03-2011, 17:29
cjwmam cjwmam is offline
AKA: Jim Hackbarth
FRC #2194 (Fondy Fire)
cjwmam is an unknown quantity at this point
If you use 5 port 4 way 3 position valve with presure center it will hold cylinder in any position and drain all air when you open your dump valve you may have to use regulator on non shaft side of cylinder to make up for area differance of shaft to avoid drift
  #56   Spotlight this post!
Unread 28-03-2011, 17:47
If you use a valve in which the center position applies pressure to both ports, the cylinder rod will center itself. This may be desirable in certain cases, but it will not easily allow variable positioning.
BE A NERD!
  #57   Spotlight this post!
Unread 28-03-2011, 21:19
AKA: Jim Hackbarth
BE A NERD!
We have a 30" cylinder on the center lift of our robot we can stop & start any where we want going up or down works great with the above valve when you open drain valve air exits both sides cylnder
  #58   Spotlight this post!
Unread 28-03-2011, 21:40
Are you sure? That seems highly illogical, to me.
BE A NERD!
  #59   Spotlight this post!
Unread 28-03-2011, 22:50
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
It would most certainly not center itself!
No matter where in the stroke it is, if the pressure on the 2 sides is equal, then the side with the larger surface area would be the side that "wins". The cylinder would extend. If a regulator were used on the other hand, then the valve would stop wherever it was.
  #60   Spotlight this post!
Unread 28-03-2011, 22:53
AKA: Alan Wells
FRC #1350 (Rambots)
Here is a diagram to help you
