Go to Post The real key to drive team coaching is to tie your jacket around your waist. Got a couple championship rings that way. - TravusCubington [more]
Unread 27-03-2011, 23:19
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
Re: The Hardest Drive System To Program:
I think that all depends on how you program it and how much practice a driver has.
After 4 years of driving Team RUSH's robots, I'd like to consider myself to be a fairly competent chassis driver. That being said, I only had experience practicing and operating with 6wd. I only had one real chance to drive a swerve-based chassis. It was programmed with one stick controlling rotation and the other translation, and it was a completely different beast than standard 6wd. That being said, with more practice it's possible I would've been able to do just as much with swerve as a 6wd robot, but I wasn't since I hadn't practiced with it.
Team RUSH Alumnus and Mentor, Mechanical Engineer
