Go to Post We also indirectly benefit from those rookie teams having well-built and working drivebases. It helps raise the level of performance across the board, making for a better competitive environment. - Alan Anderson [more]
Unread 28-03-2011, 10:18
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
Re: Logomotion: From A First Person Perspective
As Jack has pointed out this is not "perfectly legal". Wireless cameras need to be approved by First engineering and at a minimum need to be checked over by the Lead Robot Inspector prior to their use on the robot. If you used this, you risked a DQ for you and your alliance for not having the camera inspected.
Kind of scary that an alliance partner could pass inspection, make a modification like this, not tell anyone, and then my team could be DQ'd because of it. What kind of interrogation do teams need to do with each during queing?
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
Unread 28-03-2011, 10:46
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
In quals your partners DQ/red card does not affect the win or your qualifying points if I remember correctly.
Unread 28-03-2011, 11:27
Alpha Beta's Avatar
That's a good point. If they have passed inspection once, but not passed a re-inspection after a modification does <T03> apply?
<R88> If a ROBOT is modified after it has passed inspection, that ROBOT must be re-inspected.
<T03> A TEAM will only be allowed to participate in a MATCH and receive qualification, ranking, and Coopertition points only if it has passed inspection. If it is learned after the start of the MATCH that a TEAM did not pass inspection, the TEAM’s entire ALLIANCE will receive a RED CARD for that MATCH.
Unread 28-03-2011, 11:28
Aaron,
Simply ask if the team has made modifications since they last inspected. If not, go get an inspector to check the robot over in the queue.
Unread 28-03-2011, 11:46
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
In Philly 2008, we added a camera to our bot for 1 Qual match. Beforehand, I asked the LRI and the FTA. They approved it for 1 match since it was for our internal sponsorship purposes, it a non-wireless camera and its use wouldn't add time to robot resets between matches. I used some plasticy foam to make a housing for the camera, put it in an obvious location, and started recording while we were in queue.
Put some common sense into anything you put onto the robot field. It's much better to ask and be told 'no', since there is no forgiveness for this kind of thing.
GitHub
Unread 28-03-2011, 13:47
Happy Birthday! EricH EricH is online now
<T03> gets around that by assigning 3 red cards for one team participating without getting inspected--one red card per alliance member.
I would also figure that that not getting reinspected after a modification means you aren't inspected, invoking a <T03>. Just to be on the safe side, assume that; if you like living on the edge, assume the other way.
Unread 28-03-2011, 15:33
wilsonmw04's Avatar
Coach
<T03> r.
To put the burden on a third party to make sure they are inspected seems a bit off target if you ask me. If the robot has an inspection sticker, I would assume it is ready to go. It is up the the team that made a "modification" to make sure they are reinspected. This is like you getting the ticket for a person's expired tags in the other lane while waiting at a spot light...
Unread 28-03-2011, 15:39
wilson,
It is one of the prime reasons we do finals inspections. Too many teams are making mods without checking. While few in number, the changes can and do put the teams overweight.
Unread 28-03-2011, 15:53
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Regardless of legality regarding power and wireless communications, I could argue that if your robot is at 120.0 lbs, and you strap on a 0.2lb anything, you've just given yourself an illegal competitive advantage.
Unread 28-03-2011, 16:18
Racer26 Racer26 is offline
My 2 cents: The rules specifically ALLOW a battery contained in a COTS computing device on board the ROBOT. A cell phone with its internal battery would qualify under this rule. So long as its not making unauthorized wireless comms (put it in airplane mode), I think it falls under the rules for Non-Functional Decorations.
Unread 28-03-2011, 18:30
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
119.4lb was our post qual weight...
Unread 28-03-2011, 21:00
JesseK's Avatar
FRC #1885 (ILITE)
... competitive advantage.
I could always be geared for 16 ft/s using 2 CIMs
GitHub
Unread 29-03-2011, 07:20
Weight is not the only consideration when inspecting cameras added to robots.
