Go to Post A FIRST adage: You can make an Offensive robot play defense more effectively, than you can make a Defensive robot play offense. - Enigma's puzzle [more]
Unread 28-03-2011, 12:00
Ted3299 Ted3299 is offline
Team 3299 Programmer
FRC #3299 (Warehouse Crew)
Team Role: Driver
Ted3299 is an unknown quantity at this point
(Yet, another) Potential Problem with Sidecar.
I know I posted a thread earlier about how our team was unable to run motors on our robot due to some issues with our sidecar. Turn out the wiring was backward with the power from the photo sensors (in respect to the PWM's going to the sidecar) that was in turn, shorting out the 5V slots. This has been rectified and is no longer an issue.
What is currently happening now is strikingly similar but is not being caused by the same thing. It the exact same issue but isn't seemingly linked to the photo sensors like it was before. We enable the jaguars don't go solid, but we have communication to the cRIO and everything.
The big difference between now and the last problem was that we have completely re-wired our whole bot. Every splice has been soldered, every length re-done. Now I know it seems that this could be linked the the soldering but everything that was soldered is working perfectly fine, as in the photo sensors were soldered with the new configuration and are working as they normally do.
The code doesn't seem to blame here so what I'm wondering is if we might have ruined the side car.
Any input is appreciated!
Unread 28-03-2011, 12:16
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: (Yet, another) Potential Problem with Sidecar.
Try using a servo to check that your PWM outputs are working. (Don't forget to install the 6v jumper)
-- Marshal Horn
Unread 28-03-2011, 12:20
Check the 5V rail indicator.
Unplug everything from the sidecar and then plug things in one at a time until the problem comes back.
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Do you have the 12V, 6V, and 5V lights lit up? If any of the 3 are out, that's a pretty good indication of a short or hardware failure, although the former is more likely).
I know you said your code doesn't seem to be the cause, but it's still worth considering. With the removal of the watchdog, a timeout value was given to each output. If the code doesn't specify a new value within X milliseconds, the outputs time out, which would produce a "no input" signal on motor controllers (The downside of no watchdog is that it's hard to tell this kind of a software problem apart from a hardware problem, at least at a glance). It may be worthwhile to check once more for infinite loops in your code.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 28-03-2011, 13:23
Mike Wittman's Avatar
Mike Wittman Mike Wittman is offline
Plastic Man
FRC #1714 (More Robotics)
Mike Wittman is an unknown quantity at this point
It seems to me that if you had a known good DSC, it would be easiest to just plug it in and see if your problem still exists.
We were plagued with what we thought was a programming issue in Milwaukee and through process of elimination as Eric suggested we discovered it was the DSC.
Mike
Tie two birds together, though they have four wings they cannot fly
www.morerobotics.org
Learn More, Give More, Be More
Unread 28-03-2011, 13:28
Electrical Engineer
Rookie Year: 1995
Does the RSL work?
Mike Betts
As easy as 355/113...
Unread 28-03-2011, 14:02
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
It's possible that some of the itnernal circuitry of the sidecar could have shorted out. We messed up one of ours because aluminum shavings had gotten in between two DIO ports (convienently between power and ground), shorting out our robot. After a lot of testing, we determined that only parts of the sidecar had shorted out (specifically, only some of the DIOs were broken, and the rest worked fine).
What I'm saying is if you are using the same sidecar as before, when your photosensors were shorting out the 5V slots, some of the circuitry has been fried, rendering only parts of the sidecar useless.
Unread 28-03-2011, 14:49
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
If you fried some of your DIO, that's not your digital sidecar; that's your digital module that sits in slot 4 of the cRIO.
It could be that you fried your 5v power supply. This would block the PWM outputs because the PWM buffer would have no power.
-- Marshal Horn
Unread 28-03-2011, 15:49
plnyyanks's Avatar
AKA: Phil Lopreiato
That's also a possibility, but when we swapped out the sidecar, everything worked again, which makes me think that's the problem. Of course, I could be wrong...
Unread 29-03-2011, 11:03
Team Role: Driver
Sorry it took me so long to get back, LONG night working on this.
It turns out that it was the Digital Sidecar. Like the above posts, its most likely attributed to frying it so many times, ha. We finally had another team (1816, THANK YOU!) who helped us get our hand on another.
Thanks for all the suggestions and they really did help.
