Go to Post "We'll fix that in programming" - EStokely [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 27-03-2011, 12:17
cpeister's Avatar
cpeister cpeister is offline
Mech Eng Student at Waterloo
AKA: Cale Peister
FRC #0781 (Kinetic Knights)
cpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud of
Send a message via MSN to cpeister
Safety Concern at Waterloo Regional
During the elimination matches at Waterloo yesterday, one of the minibot towers malfunctioned. Between matches, a volunteer got up on a step ladder to replace the sensors in the tower. The ladder supplied by FIRST was too short and he was forced to stand on the top of this ladder to be able to reach the top of the pole.
I am not trying to attack this volunteer, he was trying to get the tower fixed so that matches could continue and was working with the tools he had. However, with this years field involving these tall towers, I think FIRST should be supplying a taller ladder. They supply spare sensors, so they must expect these to be changed with the ladders they provide. With such a focus on safety, things like this should not happen.
Cale Peister - Team 781 Alumni
Mechanical Engineering Student at Waterloo
Attended: WAT'07, WAT'08, GTR'08, WAT'09, GTR'09, WAT'10, GTR'10, WAT'11, GTRE/W'11, BUCKEYE'11, CMP'11, GTRE'12, WAT'12, GTRW'12, WAT'13, WAT'14, WAT '15
Unread 27-03-2011, 13:02
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Re: Safety Concern at Waterloo Regional
Are you sure that FIRST supplied the ladder? I've never seen one in the trucks. The one that I used at Waterford was venue-supplied.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 27-03-2011, 13:07
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
I agree that ladder was definitely too short, but I don't think FIRST supplied it.
Unread 27-03-2011, 13:34
cpeister's Avatar
AKA: Cale Peister
I was fairly certain the ladder said FIRST on it. Can someone confirm this either way?
Unread 27-03-2011, 15:21
Kara, the FIRST-built fields come with at least one ladder and a wheelchair ramp. I don't know if the FiM-built fields do; if not, it wouldn't hurt to build the ramp just in case. (I only know of a couple of cases where it's actually been used. Shouldn't be too hard to build just one and have the teams say "We would like to use it" a week or two before to make sure it gets into the trailer going to that event.) I've been up those ladders a time or two.
I wonder if FIRST was expecting people to do tower maintenance at a time when they'd have time to pull the tower down...
Unread 27-03-2011, 15:40
alectronic alectronic is offline
no team (Volunteer)
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
The way it was explained in the field manual was that you were supposed to unscrew the tower and bend it over to "normal" height to switch the lights on and off. There should have been enough slack in the signal cord to allow this. But if I had been faced with the same problem, I probably would have reached for the ladder too, messing with taking the pole down just takes too long.
FIRST does supply a ladder on the trucks, but it is not a very big one.
Unread 27-03-2011, 17:38
seannoseworthy's Avatar
seannoseworthy seannoseworthy is offline
seannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to behold
Send a message via MSN to seannoseworthy
This ladder was definitely supplied by FIRST. As seen here
Unread 27-03-2011, 20:11
c-parent c-parent is offline
c-parent will become famous soon enough
And the liability and workers comp rates just went up based on the proof provided!
Unread 28-03-2011, 14:27
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Why was a referee doing field repairs?
Unread 28-03-2011, 14:40
Brandon Holley's Avatar
Unscrewing the pole takes a significant amount of time. I too can understand why someone went straight for the ladder.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 28-03-2011, 14:59
Racer26 Racer26 is offline
Later on, dealing with the same problem (I believe 1 match later, IIRC), someone (I think this same volunteer) went up the ladder again, and the arm was not fully locked in position. THREE other volunteers came running and had him down and had the safety risk fixed in seconds before sending him up again.
FIRSTs focus on safety IS getting through to people. Sometimes circumstances still cause us to forget details. My guess is that in the heat of the moment, this volunteer simply hadnt noticed that the arm had failed to lock in. Luckily, others noticed, and did their part to remove the risks.
Unread 28-03-2011, 17:18
Btower's Avatar
Btower Btower is offline
Volunteer
AKA: Ben Tower
Btower is a splendid one to beholdBtower is a splendid one to beholdBtower is a splendid one to beholdBtower is a splendid one to beholdBtower is a splendid one to beholdBtower is a splendid one to beholdBtower is a splendid one to behold
Pull the Tower down, takes about 5 minutes to undo the base cover, detach the wires, lower the tower, remove and replace the top and put it all back together. Barely enough time for a chicken dance and much safer than a ladder.
Minbot retrival is a concern, a student using the practice filed tower at Niles got cut up catching the bot, please use gloves. There are lots of sharp edges on many of them and blodsatins are hard to remove from the carpet.
Unread 28-03-2011, 18:49
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
He volunteered to have a look at the light since he's familiar with that particular kind from his work.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
