Go to Post But their robot puts its wheels on one at a time just like ours, so we can be a HOF winner too! - Foster [more]
Unread 21-02-2011, 19:57
IRunOnJava IRunOnJava is offline
FRC #2265 (Fe Maidens)
Team Role: Electrical
IRunOnJava is an unknown quantity at this point
Unhappy Last minute autonomous help
My team is scrambling to create a working autonomous.
Our code, so far, is a modified version of the Java sample line tracker. We had to change our code to work off of two sensors because, unfortunately, one of our three line sensors came broken.
We understand that all the sample code does is move the robot forward for 8 seconds, but even with this sample code loaded on the robot, our robot does zilch. We're just trying to get our robot to show some sign of life while put in autonomous mode.
Can anybody help us out? All suggestions are appreciated.
Here's what we have loaded, autonomous-wise:
    public void autonomous() {
        getWatchdog().setEnabled(false);
        getWatchdog().feed();
        //Timer.reset();  //Resets the timer
        //Timer.start();  //Starts the timer
        int binaryValue;
        int previousValue = 0; // the binary value from the previous loop
        double steeringGain; // the amount of steering correction to apply
        // the power profiles for the straight and forked robot path. They are
        // different to let the robot drive more slowly as the robot approaches
        // the fork on the forked line case.
        double forkProfile[] = {0.70, 0.70, 0.55, 0.60, 0.60, 0.50, 0.40, 0.00};
        double straightProfile[] = {0.7, 0.7, 0.6, 0.6, 0.35, 0.35, 0.35, 0.0};
        double powerProfile[];   // the selected power profile
        // set the straightLine and left-right variables depending on chosen path
        boolean straightLine = ds.getDigitalIn(1);
        powerProfile = (straightLine) ? straightProfile : forkProfile;
        double stopTime = (straightLine) ? 2.0 : 4.0; // when the robot should look for end
        boolean goLeft = !ds.getDigitalIn(2) && !straightLine;
        System.out.println("StraightLine: " + straightLine);
        System.out.println("GoingLeft: " + goLeft);
        boolean atCross = false; // if robot has arrived at end
        // time the path over the line
        Timer timer = new Timer();
        timer.start();
        timer.reset();
        int oldTimeInSeconds = -1;
        double time;
        double speed, turn;
        // loop until robot reaches "T" at end or 8 seconds has past
        while ((time = timer.get()) < 8.0 && !atCross) {
            int timeInSeconds = (int) time;
            // read the sensors
            int leftValue = left.get() ? 1 : 0;
            //int middleValue = middle.get() ? 1 : 0;
            int rightValue = right.get() ? 1 : 0;
            // compute the single value from the 3 sensors. Notice that the bits
            // for the outside sensors are flipped depending on left or right
            // fork. Also the sign of the steering direction is different for left/right.
            if (goLeft) {
                binaryValue = leftValue * 4 + rightValue;
                steeringGain = -defaultSteeringGain;
            } else {
                binaryValue = rightValue * 4 + leftValue;
                steeringGain = defaultSteeringGain;
            // get the default speed and turn rate at this time
            speed = powerProfile[timeInSeconds];
            turn = 0;
            // different cases for different line tracking sensor readings
            switch (binaryValue) {
                case 1:  // on line edge
                    turn = 0;
                    break;
                case 5:  // all sensors on (maybe at cross)
                    if (time > stopTime) {
                        atCross = true;
                        speed = 0;
                    break;
                case 0:  // all sensors off
                    if (previousValue == 0 || previousValue == 1) {
                        turn = steeringGain;
                    } else {
                        turn = -steeringGain;
                    break;
                default:  // all other cases
            // print current status for debugging
            if (binaryValue != previousValue) {
                System.out.println("Time: " + time + " Sensor: " + binaryValue + " speed: " + speed + " turn: " + turn + " atCross: " + atCross);
            // set the robot speed and direction
            robotDrive.arcadeDrive(speed, turn);
            if (binaryValue != 0) {
                previousValue = binaryValue;
            oldTimeInSeconds = timeInSeconds;
            Timer.delay(0.01);
        // Done with loop - stop the robot. Robot ought to be at the end of the line
        robotDrive.drive(0,0);
Unread 21-02-2011, 20:06
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Last minute autonomous help
You say two? Good luck with that, it can be done, but you will require either gyros or encoders. Keep a record of the speeds, or the angle it has veered off to. Mount a line tracker in the front, and the other one in the back so it always is triggered. Do some calculations. I too have to work on the autonomy. I will be writing my own from scratch.
Unread 21-02-2011, 21:33
alexhenning alexhenning is offline
WPILib Developer
FRC #0348
alexhenning will become famous soon enough
We don't use line tracking, we use encoders we drive a fixed distance straight and place a piece.
Since you're running so late. try code that powers your drive forward at say 1/3 power for 5 seconds. Tune it until it just bumps the wall and then place a piece. Make sure you keep a good battery, but I think that's your best bet for a last minute autonomous BEFORE you ship.
Alternatively, look up teams going to your first regional and see if there's anyone like my team who hasn't used there line sensors and wouldn't mind giving you one.
Unread 21-02-2011, 21:58
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Are you getting any response when you deploy? If the robot does nothing, the robot is probably quitting unexpectedly, which you would receive. As for working with two photosensors, if you are dead set on using them (instead of other sensors or dead reckoning as has been suggested) I would place them directly adjacent to each other, so they can both be tripped by the tape at the same time and working with that. There may be some interference however (one receiving the reflected light from the other and returning a false positive) and it obviously won't be ideal.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 26-02-2011, 03:06
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Personally I find the encoders a more reliable way of making an autonomous algorithm. You simply drive until you hit a certain number of encoder counts. Then you move your manipulator. Then you drive some more. Then you place. Then you reverse.
If you're using the Iterative Robot template, the easiest way to do this is do create different state machines for the drive and each of your mechanisms. Then you create a main state machine that simply feeds these other machines values and waits for the drive or manipulator to be in place. Once the structure was created, fine tuning the numbers only took a few hours, and now we can place on any of the high pegs and the middle second level pegs reliably (as long as we're using a fresh battery that is).
www.sharkattack744.com
Unread 26-02-2011, 12:41
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I personally would disagree with you on that: because our robot is driven by chain, there are a lot of noise in the encoders from the chain jerking around. I suggest one day just put the robot on blocks and let the motor run through from 0 to 255 PWM and graph the encoder data vs the PWM. You will be surprised at the noise.
Unread 26-02-2011, 12:52
WPILib Developer
FRC #0348
My team used encoders and we have a reliable autonomous even though our robot has chain. The noise is minimal, I haven't graphed it, but after ~30 successful runs, I wouldn't worry about it unless your chain is really lose or otherwise acting up.
The other thing about encoders is that with some math, you can convert it to feet. You know how far back you start, so drive N feet forward and then place the piece. All the fiddling is with the arm then.
Unread 28-03-2011, 00:58
PriyankP's Avatar
PriyankP PriyankP is offline
FRC #0188 (Woburn Robotics)
PriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud of
Sorry to bring up this relatively old topic but I was wondering how are you using encoders to go to a certain distance? Do you just have PID and Setpoint encoders to some number? Or are you using something else too?
Any other teams out there willing to share how they use their encoders in autonomous?
Champs Schedule Highlighter App [CD Thread]
#### XYZ Regional Finalists
Unread 28-03-2011, 17:50
WPILib Developer
FRC #0348
I have two encoders hooked up to jaguars running CAN one for the left side and the other for the right side. The autonomous does P (No need for ID) so that it slows down as it gets closer until it hits the wall going pretty slowly. This runs reliably as long as it's lined up and the left and right sides act the same. i.e. You jam both joysticks forward and it actually drives straight-ish.
Here's the relevant code.
	    leftDist = bot.dt.getLeftDist() - leftStart;
	    rightDist = bot.dt.getRightDist() - rightStart;
	    double left = gain * ((distance - leftDist) / distance);
	    double right = gain * ((distance - rightDist) / distance);
	    bot.dt.drive(left, right, bot.gyro);
distance is the distance you wish to travel in feet.
gain is the initial value that gets toned down as you drive (Currently using 0.7)
Hopefully the rest of the code is clear enough that it makes sense. If you have anymore questions feel free to ask. Also, you can PM me if you want to see our full autonomous code.
Unread 28-03-2011, 21:31
PriyankP's Avatar
I was thinking of putting on two encoders to get the base to stop within 6 inches of the target distance without overshooting and without travelling slowly. Not sure if that's possible yet because we don't have encoders on the base yet but I would imagine I'll need I and D. The biggest problem that I'll have is momentum because I plan on running the auto at close to full speed.
If you don't mind, can you please send me the code that has to do with your base? I'm sure I can learn from it as I can't find many resources that explain the concepts. :O
Unread 28-03-2011, 21:50
WPILib Developer
FRC #0348
Chiefdelphi has a number of helpful post on PID, for starters: http://www.chiefdelphi.com/media/papers/1823
Is there any reason you can't overshoot? Fast speed to wall, then slowly backing up 6 inches may be better, unless it smashes your arm or something. Don't forget, you have 15 seconds, consistent even if slow is better than inconsistent and fast.
Hope that helps a bit.
Unread 29-03-2011, 19:19
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
At the Waterford District we used encoders, drove a set amount of cycles forward, and then had our arm code place our tube, except it only worked 50% of the time because our field people liked to not line it up straight so it went off to the side quite a bit.
At Ann Arbor we used line trackers to keep our robot straight while using encoders to set our distance. But our field people would have it too far forward or back so it still wasn't reliable.
At Troy we're looking forward to trying to use a camera positioned on our arm to locate the top peg and score, with little or no use for the encoders or line trackers.
As for only using 2 line trackers I wouldn't recommend it. Last year we tried that and sent half of a competition trying to borrow one after 5 unsuccessful matches.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 29-03-2011, 20:16
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Did any other team not use encoders/ultrasonic for their autonomous?
My team only had line sensors, we're counting on timers to do the rest of the work for us (arm).
And if so, how well did the timers work out for your team? Do you think we would have enough time to implement encoders on our robot in the pits?
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 30-03-2011, 19:20
WPILib Developer
FRC #0348
In the past we've run autonomous without encoders, the biggest problem we had was that performance (especially for turning) varied on battery charge, so that if we didn't regularly switch out the batteries we'd have issues. As long as your conscious of batteries and keep them charged, there shouldn't be any issues, as long as it worked consistently during testing.
How long would it take to implement encoders? Assuming you plan for it, it should be quick and doable with one or two runs to the practice field.
BEFORE YOU GET THERE
1. If you ave the encoders at your shop and can solder the wires so that you can plug it straight into jags or digital sidecar
2. Figure out where you're mounting the encoders (cimple boxes?) and the gear ratio to the wheels
3. Figure out the diameter of the wheel and the gear ratio between the
4. Using the diameter of the wheel and gear ratio to calculate how many feet you go in one rotation of the encoder
5. Write code using the above equation and P(and possibly ID) to get to your target position (I think starting location is ~19 feet from the driver station)
6. Double check your code.
WHEN YOU GET THERE
1. Attach encoders to robot
2. Wire encoders
3. With robot on blocks check that autonomous behave sanely (have somebody on the Estop)
4. Test on practice field (have somebody on the Estop)
5. Assuming that the behavior was close enough to sane..
6. Continue testing on practice field and matches until it's consistently scoring.
(Similar applies to arm.... might need more math though)
Hopefully that helps, the great thing about sensors is that you can write alot of code ahead of time. Good luck if you go through with using encoders.
Unread 30-03-2011, 23:08
Dacilndak's Avatar
Dacilndak Dacilndak is offline
Matt'); DROP TABLE Users; --
AKA: Matthew Haney
FRC #3729 (Red Knights)
Dacilndak is an unknown quantity at this point
Our team is using 3 front-mounted light sensors with great success. No encoders, no ultrasonic, no timers.
We're using C++. Our autonomous program manages a state machine that gets input from the light sensors and decides what to do based on them. Our algorithm is as follows:
Light sensor values (L/C/R)-----------------------State to execute
000--------------------------------------------------move() - go forward until you see the line
010--------------------------------------------------move() - this is ideal, we're on the line
100--------------------------------------------------correctLeft() - move left to see the line
110--------------------------------------------------also correctLeft()
001 and 011----------------------------------------correctRight()
101--------------------------------------------------at the fork; correctLeft() or correctRight() based on a switch on the robot
111-------------------------------------------------placeTube()
After executing placeTube(), the program quits the state machine and retreats back several feet, then turns on the spot (~180 degrees, but it's not perfect since we don't have encoders or a gyro). Generally, getting the tube on the rack takes about ten seconds, and we're only driving the motors at 40% for drive and 60% for turn.
Team 3729 - Raiders - Programming Team Co-Captain
2011 Colorado Regional Semifinalist
2011 Colorado Regional Rookie All-Star Award
2011 Colorado Regional Highest Rookie Seed Award
