Go to Post The obvious solution is to only allow the real world to have negative jade induction coefficients. - EricVanWyk [more]
Unread 28-03-2011, 18:37
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
timing in program
How do you make something happen after a certain amount of time for a certain amount of time. Say make a motor move for after 5 seconds for 5 seconds. Can you send me a pic? I am just trying to figure out how to use the timing vi's.
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
Unread 28-03-2011, 20:16
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Re: timing in program
in auto or telop?
Expect the best, Prepare for the worst
Unread 28-03-2011, 20:21
auto
Unread 28-03-2011, 21:38
Here's one way to do what you asked. The first frame of the flat sequence will wait for 5000 milliseconds before completing and letting the second frame begin. The second frame contains a while loop that will terminate after 101 iterations, with each iteration setting the motor speed and waiting for 50 milliseconds. The final frame of the sequence turns the motor off.
Using a flat sequence is overkill for something this simple, but it provides a framework for adding more steps if desired.
Unread 29-03-2011, 17:49
thank you.
