Go to Post I've come to the conclusion that the only way Pat's awesomeness can be explained is.... Pat Fairbank is a cookie. - Jonathan Norris [more]
Unread 13-03-2011, 15:07
Aakash Gihwala's Avatar
Aakash Gihwala Aakash Gihwala is offline
FRC #1345 (The Platinum Dragons)
Aakash Gihwala has a spectacular aura aboutAakash Gihwala has a spectacular aura aboutAakash Gihwala has a spectacular aura about
Send a message via AIM to Aakash Gihwala
Re: pic: 3729's minibot
How exactly are you mounting your magnets?
Aakash Gihwala
Unread 13-03-2011, 16:20
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Two magnets each directly opposite each other sandwitching the 1/16 inch Lexan between them. Polycarbonate glue is used to keep them in position. This puts one surface of the magnet about 1/16 inch above the surface of the pole.
Unread 14-03-2011, 00:04
PingPongPerson's Avatar
PingPongPerson PingPongPerson is offline
Hardcore Robot Addict
AKA: Michael Groom
FRC #0955 (CV Robotics)
PingPongPerson will become famous soon enough
Are lamp switches legal? The rules say only "2 common household lightswitches"
Team 955
Raiderbot
Unread 14-03-2011, 00:29
The Lucas's Avatar
CaMOElot, it is a silly place
Yes, if they are sold as a "light switch" for household use. Read Team Update 12 for the full interpretation.
Robot Inspector
Unread 14-03-2011, 17:06
AKA: Michael Groom
Team 955
Raiderbot
Unread 14-03-2011, 19:03
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
From TU #12
A note about “light switches” permitted on the MINIBOT:
We have previously stated in the Q&A that “light switches” are only “light switches” if they are commonly used in a wall mounting box. Rule R92-N, however, uses the language “common household light switches”; which can have a much broader interpretation. Given the discrepancy in specificity between R92 and the Q&A statements, we defer to the manual. Therefore, “light switches” permitted on the MINIBOT are not confined to those used in wall mounting boxes; anything sold as a “light switch” for household use is allowed. The Q&A answers will be revised.
Lamp switch = light switch and yes you can buy them at Home Depot with the rest of the "light switches"
Unread 14-03-2011, 19:24
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
Be careful about aluminum rod pressed onto the motor shaft unless you are using a very strong grade of aluminum. We used 6061 at first and it was a miserable failure. We ended up with 1/4-20 steel bolts as shafts and it works great.
Unread 14-03-2011, 19:45
AKA: Michael Groom
Thanks. Sorry I asked twice I didn't think it posted the first time.
Team 955
Raiderbot
Unread 22-03-2011, 19:39
Free Willy's Avatar
Free Willy Free Willy is offline
Free Willy is an unknown quantity at this point
How did you attach the bolts to the motor shaft?
Unread 22-03-2011, 22:27
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
By drilling a hole in the center of the bolt that is an interference fit and carefully pressing the motur shaft into it
Unread 28-03-2011, 18:53
Free Willy's Avatar
Originally Posted by NOV8R View Post
A few answers: The shafts are 2 inch long by 3/8 inch aluminum rod drilled with a 3/32 drill. They are then pressed on with an arbor press. The friction material is 3/8 inch OD Latex stretched on after running hot water over it for a few seconds. The white object just below the motors is a pole guide made from a 1 1/2 pvc pipe fitting. In addittion two magnets help hold the minibot to the pole. The battery is held in position between two pieces of 1/2 aluminum tubing. Inside this tubing are guide pins attached to the deployment tray. There are two on/off lamp switches and one limit switch that control the motors. The first switch turns on the motors when the bot contacts the pole. When the second switch contacts the top of the tower it shifts the motor to half power so the bot will slowly decend the pole. A limit switch on the bot's base then turns off power when it comes down the pole and makes contact with the base. Weight management of the minibot is essential. Let the bot get to heavy and you'll smoke the motors.
How do you get the switches to change the motors to half power?
Unread 28-03-2011, 20:31
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
We used a light switch to hook a 4 ohm resistor in series with the motors. Since all the recent problems with switches and getting them thru inspection we're using the KoP limit switches to short the motors to decend. It's working great.
Unread 28-03-2011, 20:35
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Resistors aren't allowed on the minibot, by the way.
Unread 30-03-2011, 22:43
Free Willy's Avatar
Thanks for the answers!
1 last question, how do you secure the surgical tubing to the motor shaft? We were able to get it on, but it keeps sliding off. Thanks!
Unread 30-03-2011, 23:42
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
It will stay on if:
1. You have enough contact area (>1" has worked for me)
2. The ID of the tubing is the same, or smaller than the OD of the shaft
Chances are it will take some finger strength to get the surgical tubing on without a lubricant. Its what I have been doing for weeks.
Some teams have said they use warm water or rubbing alcohol. For whatever reason we can't get warm water in our building so I haven't been able to try it.
Now that you know, can you explain why the tubing behaves this way?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
