Go to Post I'm not basing success on winning a regional. Success is learning by building the best system you can. In the engineering industries, the best system is the one chosen. - AdamHeard [more]
Unread 28-03-2011, 17:26
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
Watchdogs
Can someone give me a brief overview on what watchdogs are? what they do and how they work.
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
Unread 28-03-2011, 18:21
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: Watchdogs
A simple explanation is a watchdog is a protection in the software to be sure your code doesn't take too much time to execute. One example that may cause this is if your code gets stuck in an infinite loop.
How does this protect your robot (and protect you from getting hurt)?
Let's say you command your drive motors to full power. Then let's say your code gets stuck in an infinite loop somewhere. In this situation, your motors would be at full power forever and your robot would crash into something, which is bad. Since you aren't feeding the watchdog during the infinite loop, eventually the watchdog would time-out, killing the power to your motors.
Basically, the watchdog is protection in your code to kill your motors if something goes wrong in your code.
Unread 28-03-2011, 18:26
Re: Watchdogs
Now watchdogs are virtual right? how do you program them.
Unread 28-03-2011, 20:57
Re: Watchdogs
In the context of FRC and the 2011 software, the watchdog is there to keep your robot from going out of control due to loss of communication. It is all automatic. You don't do anything to program it.
The motor safety feature is sort of a minor watchdog that will help keep your robot from going out of control if you fail to set the drive motor values every tenth of a second. You should never need to "program" it. If you really know what you are doing, you can disable the safety feature to make certain programming patterns possible. If you're extra paranoid, you can enable the safeties on motors other than drive motors. But there's no reason for you to do anything with the safeties other than make sure you keep it happy by controlling the motors on a regular basis.
Unread 29-03-2011, 19:38
Re: Watchdogs
oooooooohhhhhhhh...well that is handy.
