Go to Post Texas! Here we come! - Harrison [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 28-03-2011, 21:04
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Performance Scouter
how dose sorting by telop do?
and there is minor lag when switching the way you want to sort by kinda annoying
sorry for the critiques but i really like it and i can use a remote program to control my laptop from my ipad and it works great
the number pad is a little annoying
Unread 28-03-2011, 23:04
Bryany's Avatar
Bryany Bryany is offline
FRC #1094 (Channel Cats)
Bryany is a jewel in the roughBryany is a jewel in the roughBryany is a jewel in the roughBryany is a jewel in the rough
Sorting by teleop arranges the teams from highest average teleop score (total earned divided by matches run) to lowest. Same with Auto and Minibot. If the display mode (bottom right corner) is set to "Total", what's on the screen won't necessarily match the sorting, because that is just total points earned, not average. If you set display to "Average" then the visible numbers will match the sort. There is the same difference between sorting by "Total" and by the percentage bar. The Total is simply the total earned, white the bar represents the total divided by matches played.
I hadn't thought about that. I had been testing it on my fast computer, so I hadn't noticed much lag. About how long is the lag? I don't know of an easy way around it. (well I could maybe shorten the lag when sorting by team number to match the others)
By all means, critique as much as possible! That's how progress is made!
When running it from your ipad, is there an alternate way to type numbers (or letters, for the file prompt), that I can remove the number pad entirely, or should it simply be altered?
Unread 28-03-2011, 23:18
With the iPad I'm using a program called team viewer to control my laptop with my iPad . It works fine. I can bring up the iPads keyboard to type numbers and letters. The issue with the keypad is that it's big and kinda in the way. Maybe there is a way so the user can move it around. Also I do not know if this is happening to you but when ever I put in a team number it beep/makes a noises that is quick annoying since I have to put in 6 different teams. Another idea for the keypad is to have a checkbox for the user to either have the keypad or not. But otherwise this is a great program for teams that do not have a a lot of members for scouting. Its nice and very organized and easy to sort data basked on what you want. The other question I had was if you could put in all the matchs before they even start. Then go in order and a follow the matches so you would not have to worry about that in between matches? Once again this is a nice program.
Unread 29-03-2011, 00:25
Bryany's Avatar
I can add that. I'll try to have that by tomorrow.
I have no idea about the beep. There are no sounds intentionally programmed in. Did it make that sound before the number pad? The checkbox should be no problem. I guess I'll put it in the scheduler screen. (running out of room on the main screen)
Actually, that is already part of the program, although that reminds me that I need to include that in the instructions. In the scheduler screen, click New Match a few times, and then click on a grid space to input the team that goes there. They will then be entered in automatically when that match comes up. If you ever miss a match, you can rename the current match being recorded in the play screen by clicking on where it says the current match. I think I will add the option of changing the current match from the scheduler screen though, now that I think about it.
And I did get the opening file prompt working, and it is in the current version. I also changed the main file extension to .tmm, as there are other programs that use .ini, and bad things could happen if the user loaded something else's file. (you can still load old .ini's though) Again, let me know if it's worth it, or if it should go back to the way it was before.
Thanks for all the great feedback!
Unread 29-03-2011, 17:01
Bryany's Avatar
Post Re: Performance Scouter
Okay! I just added the options of hiding the number pad, moving the number pad around, and the other things I mentioned above. (the number pad disable button is attached to the number pad) I also fixed an issue with the touch scroll hopping around when you scroll too high.
I wish it would allow me to edit the original post so I could summarize all the changes. Oh well.
[IMG] code is Off
