Go to Post Sleep?! How am I supposed to do that with the build season done?! There are still practice bots to make! - [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 28-03-2011, 23:04
Bryany's Avatar
Bryany Bryany is offline
FRC #1094 (Channel Cats)
Bryany is a jewel in the roughBryany is a jewel in the roughBryany is a jewel in the roughBryany is a jewel in the rough
Re: Performance Scouter
Originally Posted by tomy View Post
how dose sorting by telop do?
Sorting by teleop arranges the teams from highest average teleop score (total earned divided by matches run) to lowest. Same with Auto and Minibot. If the display mode (bottom right corner) is set to "Total", what's on the screen won't necessarily match the sorting, because that is just total points earned, not average. If you set display to "Average" then the visible numbers will match the sort. There is the same difference between sorting by "Total" and by the percentage bar. The Total is simply the total earned, white the bar represents the total divided by matches played.
and there is minor lag when switching the way you want to sort by kinda annoying
I hadn't thought about that. I had been testing it on my fast computer, so I hadn't noticed much lag. About how long is the lag? I don't know of an easy way around it. (well I could maybe shorten the lag when sorting by team number to match the others)
sorry for the critiques but i really like it and i can use a remote program to control my laptop from my ipad and it works great
the number pad is a little annoying
By all means, critique as much as possible! That's how progress is made!
When running it from your ipad, is there an alternate way to type numbers (or letters, for the file prompt), that I can remove the number pad entirely, or should it simply be altered?
[IMG] code is Off
