#29
Re: Solution: Variable position of cylinder in compliance with <R74>
If it's a 3-position valve that is center pressure, then you can only have three possible positions of the cylinder, without adjusting the regulator. If you use a center-closed valve, like I show in the schematic I posted, theoretically, you can have an infinite number of cylinder positions.
