Go to Post There's a fine line between cockiness and confidence. Confidence is one of the major keys to success and happiness in life. As long as one can carefully stay on the right side of the line, staying connfident while remaining humble, and ego can be quite beneficial. - Karthik [more]
Unread 29-03-2011, 14:46
Re: servo jitter when running Jaguar on RS-775
Originally Posted by EricVanWyk View Post
Further evidence that the Banebots chassis fault issue is actually a bigger deal than Banebots wants to admit.
Teams, please check your `bots for this.
When we were having the issue, I was able to isolate it to the 775s by pulling their breakers and disconnecting the leads (separate actions- as to isolate the jag). Both of these things did away with the jitter.
Interestingly enough, of the two servos we had connected, only one PWM port was driving the jittery one. Switch PWM port, the other jitters.
Unread 29-03-2011, 16:26
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Yeah, not to pile on, but we just pulled 4 banebots new out of the box. 1 had a case short, and 2 had bad bearings - with a slight outward load on the shaft the motors would lock up hard and not rotate at all.
Unread 31-03-2011, 13:39
I am going to throw a guess on this one where the Jag breaker isolates it and switching PWM servo outputs moves the problem. The Jag is capable of very high rise times and therefore is likely to put some wild RF signals on the motor leads. If the 775 has a case short, caps across the motor leads will not help. I have experienced noise currents traveling on wire and then crossing over to another wire and causing problems. Sometimes, RF ferrite beads around the conductors can shunt the noise. My suspicion on the 775 problem is that you will find it to be a greater problem when driving in one direction vs. the other. If that is indeed the case, then there are significant currents driving through the case to the common electrical lead on the Jag and back out to anything connected to the Jag with the same common terminal.
Unread 31-03-2011, 20:19
Brandon Holley's Avatar
Your guess seems right to me. Our servos only showed the issue when the elevator was driving up (aka: under the largest load).
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 01-04-2011, 07:34
Gdeaver Gdeaver is online now
FRC #1640
Has any one tried adding a cap to the servo wire as close to the servo as possible? While it may not work in this case, It has solved twitchy servo problems on some of my projects in the past. Cap on the + and - .
Unread 11-05-2011, 09:38
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
I've taken of the RS775. It did indeed have a short to its case. (About 1 ohm)
There was nothing else connected to the frame, but considering the long servo runs, I don't doubt that the servos were jittering from induction onto their signal line.
I'll get around to testing sometime.
-- Marshal Horn
Unread 11-05-2011, 11:15
Tom -
Do you remember what port jittered and what port was good?
