Go to Post I think this thread needs a reminder that there's no h in mecanum. ;) - Lil' Lavery [more]
Unread 29-03-2011, 15:02
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Re: pic: Lamp_Switch
Originally Posted by PayneTrain View Post
I can't speak for the team truthfully, but 88 appeared to be using that exact switch on their minibot in Baltimore.
If you are a direct drive under 5 pounds, you should be dandy.
Yes, team 88 uses the same toggling light switch (either from Home Depot or Lowe's). We can also confirm that it is possible to hit the top so hard that the switch mechanism is driven through the back of the switch housing. We added a bolt as a mechanical stop to prevent that from happening.
