Go to Post Sometimes, it's all about the people. - nixiebunny [more]
Unread 27-03-2011, 16:14
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Top Ten Reasons Robot Loses Com in a collision ?
Just wondering if anyone can contribution ideas as to possible causes to our robot occasionally losing com in collisions on the field. At this point of time I am not aware that the CRio had rebooted as a result but will try to confirm.
This is what we have looked at.
Bridge power jack contact looks solid. (will hot glue it in anyway)
Good soldered connections from bridge to converter
Converter to 12v plug in power distribution board looks solid
Crio power power plug, Crio power plug in power distribution board.
Network cable contacts at Crio and bridge ? Any risks there ?
Terminal lugs in main power distribution board possibly coming loose (main circuit breaker lugs, power distribution lugs)
Loosening contacts on battery terminals
Any other suggestions or recommended good practises that may not be obvious ?
Anyone know how good the regulation is for the 12 and 24 volt outputs on the pdb ? How low can the battery go before the CRio or Bridge is at risk ?
Unread 27-03-2011, 16:20
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Re: Top Ten Reasons Robot Loses Com in a collision ?
Check for ground shorted to the robot frame. The cRIO and camera are both chassis grounded and must be isolated from the robot frame. Also, if you are using any of the RS-775 motors make sure they don't have a lead shorted to the case.
Unread 27-03-2011, 17:07
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Anderson cables disconnecting even momentarily will reboot the robot.
cRIO power cables coming undone
Radio power cable getting knocked out from the radio. We lost com twice at an event, taped the radio power cable in, and were fine the rest of the event.
Zip-tie your anderson connectors together, check you cRIO power, and tape down your radio power cable. These are the three problems we had and our three solutions.
Unread 27-03-2011, 22:01
For how long do you lose communication? 20-30 seconds is a cRIO reboot. 45-60 seconds is a DAP reboot. 1-2 seconds might perhaps be a network cable issue.
The 12v and 24v boosted supplies out of the PDB are good down to less than five volts input from the battery.
Unread 27-03-2011, 22:12
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I would say make a big PCB board instead of having tons of wires. If you can't don't use connectors, solder them.
Unread 27-03-2011, 22:13
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Reason number 1
Because its not an IFI controller.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 29-03-2011, 15:06
de_ de_ is offline
AKA: Dave Edwards
More than 1-2 seconds. Will watch closely at regional next weekend.
Unread 29-03-2011, 15:09
Crio is disabled when battery falls below 5.5 volts. 24 volt, 12 volt and 5 volt power supplies fail at about 4.5 volts at the battery input to the PD.
Unread 29-03-2011, 20:17
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I haven't seen anyone mention the reset button on the router. The old one was a spring-retained button and could be triggered by slamming down on the bump last year. We hot glued that one too.
Unread 30-03-2011, 00:22
LightWaves1636's Avatar
LightWaves1636 LightWaves1636 is offline
is all over it.
AKA: Sarah Le
LightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to behold
Send a message via AIM to LightWaves1636 Send a message via Yahoo to LightWaves1636
We lost comms because our battery slipped out and knocked into our PDB connections. So
A: Secure the battery really well and
B: Protect your electronics in a well ventilated area
FLL Team - Hackberry Hill Elementary - Arvada, CO ('08 - '10 Coach)
FRC Team 1636 - Reds Robotics - Arvada High School - Arvada, CO ('05 - '07 Alumni)
FRC Team 1583 - Rambotics - Ridgeview Academy - Watkins, CO (Volunteer/Supporter)
FRC Team 2859 - Blasterbots - CSM Robotics Outreach - Golden, CO ('09 - '10 Coach)
FRC Team 3320 - Miracles & Machines - Eastside Memorial High School - Austin, TX ('10 - '12 Mentor)
Unread 30-03-2011, 00:30
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Originally Posted by nuggetsyl View Post
Reason number 1
No, reason #1 is:
"Because it's not CHUCK NORRIS!"
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 30-03-2011, 00:32
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
The number one problem at the regionals that I have been to has been the Ethernet cable between the bridge and the c-rio after collisions teams would lose comms so make sure the connections are secured
Expect the best, Prepare for the worst
Unread 30-03-2011, 00:41
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Originally Posted by Danny Diaz View Post
No, reason #1 is:
THAT'S IT! I knew there was a feature missing.
In all seriousness - lots of good tips in the thread. Definately make sure you're connected to the correct PD outputs as well. Though as pointed out, if you get a reset, it would be longer than a few seconds.
